Steering wheel removal
Old Oct 12, 2016 | 04:45 PM
highoctane74's Avatar
highoctane74
Can someone confirm the size of bolt required for puller to remove steering wheel please. My research found 5/16 - 24. Just want to be sure before I drive all the way to town, thanks.
Tried pulling steering wheel and someone had bolts broken off where puller screws in. I think I have a challenge ahead of me. Never had one this tough.
Old Oct 12, 2016 | 04:54 PM
AK FORD GUY's Avatar
AK FORD GUY
Spray some penetrating oil into something to catch it and then dab it around the splines with a toothpick, while you run in to grab the bolts it should have some time to soak in. That might help loosen it.
Sorry, I don't know the bolt size though...
Old Oct 12, 2016 | 07:24 PM
highoctane74
Well that was the right size!
Old Oct 13, 2016 | 08:05 PM
duste's Avatar
duste
If you can't use a puller on it , try loosening the nut till there is 3 or 4 threads left holding it, use a plastic or rubber hammer and give it a couple hits under the wheel and as close to the center as possible while pulled up on the wheel with your free hand. This has worked well for me in the past , the first time ( 25 yrs ago or so) I didn't leave the nut on and almost ate the wheel when it let go, and no it didn't damage the wheel.
Old Oct 14, 2016 | 12:03 AM
highoctane74
I have taken many off, and never seen anything like this. The po must have tried removing it in the past. Both the holes for threading the bolts for the puller had broken bolts in then. I had to drill them out and use a screw extractor. Not fun. Had a hell of a time getting it off, never had a problem before. Was like it was rusted on!
Old Oct 14, 2016 | 12:10 AM
highoctane74
Old Oct 14, 2016 | 08:47 AM
HoustonDave's Avatar
HoustonDave
I know this is counterintuitive but when you have it soaking in penetrant, tighten the main nut holding it on - that helps break the corrosion holding it in place. Tighten, loosen, use the puller... eventually it will work loose. I'd be careful with the rubber mallet method - have removed a lot of wheels like that in the past but you are dealing with 40 year old plastic here. Might work, but you might crack something with an ill-aimed hit.
BocaAero95
Aerostar
Jul 19, 2017 10:40 AM
Witty73
Apr 16, 2010 06:27 AM
compman25
Aug 27, 2009 11:48 PM
rnelson664
13
Mar 24, 2007 02:59 PM
bci101tractors
Aug 15, 2006 09:18 PM
