Removing Steering wheel
Old Aug 12, 2004 | 11:01 PM
sas's Avatar
sas
This is driving me mad
I'm trying to remove the steering wheel from my 97 Exporer but it won't come off. I removed the airbag, unscrewed the center torx bolt, stuck my puller on and broke the puller. So I got another one and it won't move it either, I can see the puller bolts bending as I try to unscrew the wheel. Anyone got any tips or tricks to try ??
I've even tried a big hammer
Old Aug 13, 2004 | 12:54 PM
87 XLT's Avatar
87 XLT
How to do this isnt explained in your Haynes manual?
Old Aug 13, 2004 | 02:43 PM
LV Dan's Avatar
LV Dan
What grade bolts are you using to to thread into the steering wheel? I wouldn't use anything less than a grade 5. Cheap pullers and Home Depot hardware is grade 3.
Old Aug 13, 2004 | 03:08 PM
sas's Avatar
sas
I've got it, ended up drilling 2 holes in the steering wheel frame for bolts.
I've removed a few steering wheels in my time but none that tight!!
thanks for the advice LV Dan
