Electric wiper
Old Jan 7, 2013 | 01:23 PM
  #61
4tl8ford's Avatar
4tl8ford
Originally Posted by ALBUQ F-1
It might be worth signing up on the HAMB and asking over there. Our trucks are among the last using vacuum wipers so many of the guys over there have fab'd up wipers from more modern stuff. Hokey *** Message Board - THE H.A.M.B.
Originally Posted by 1930 Dodge
Thanks, I do have the question posted on another hot rod board and will wait to see what sort of a response I get there.
From the other hot rod board
I have read that these wiper motors originally used on 4-4.5 amps max but this was stated by someone that has led me astray a couple of times now and I am done relying on his in-put so this may or may not be correct.
NICE
Old Jan 7, 2013 | 01:31 PM
  #62
Doc's Avatar
Doc
Or how about this one, from the same hot rod board:
"I am having trouble finding information I can rely on when it comes to the wiper motor in my 52 truck. There are some great guys that know electrical very well on the mid eighties stuff ( which is where alot of my electrical components come from ) but when it comes to the earlier stuff they are not so knowledgeable and some of the guys that deal more with the earlier stuff are just throwing things out and from what I found really are not helping because they have no real world experience with what I am dealing with."
Old Jan 7, 2013 | 02:06 PM
  #63
1930 Dodge's Avatar
1930 Dodge
Originally Posted by Steve_B
This set up was made by Lucas (q jokes about Lucas electrics being made of smoke) and fitted to many UK cars in the 60s and 70s. It was used in minis, jags, vauxhalls and probably a few others
It's easy to fit and modify to suit as its cable drive so the motor can be mounted out of the way, gives 2 speeds with auto park, The tubes are easily cut to adjust spacing between the wipers
All parts are available new
Wiper Systems & Parts - Classic &AMP Vintage Car Parts from SVC - The Best Prices
I've used one in my truck, there are a few pic's in my gallery
Thanks, I would gave to find one in the junkyard complete, buying new like that would nickel and dime me to death.
Ive hopefully found a better solution anyway but thanks for the info
Old Jan 7, 2013 | 05:34 PM
  #64
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Here's a friendly reminder to you....
.......you're not the only person who visits and/or participates in multiple online forums. That being said, its generally bad form to make disparaging comments about those who have been patiently sharing their experience and knowledge with you on other forums.
Or in simpler terms..... ...Don't pee in the pot you're drinking out of.
Good luck
Bobby
Old Jan 7, 2013 | 06:25 PM
  #65
The Horvaths's Avatar
The Horvaths
I measured 6 Volt wiper motor current at 4 to 4.5 Amps with a wet windshield (load does impact current draw). I run mine, and my gauges, from a 12V to 6V DC-DC converter that I pulled out of my electronics junk box.
I hope that this helps.
Old Jan 7, 2013 | 07:18 PM
  #66
bobj49f2's Avatar
bobj49f2
Good luck
Bobby
That's funny
Old Jan 7, 2013 | 07:25 PM
  #67
bigwin56f100's Avatar
bigwin56f100
Here is what I dont understand, 66 posts and the answer was given way back when about the voltage reducer 4-4.5 amps, and again by The Horvaths
As stated 4-4.5 amps when wet
Why would you worry about the amperage when the glass is dry? I dont use my wipers when the windshield is DRY!
I use Rain X!
Old Jan 7, 2013 | 08:51 PM
  #68
The Horvaths
You can use a 1.3 to 1.5 Ohm resistor that is rated at fifty Watts or more. Mount it where it can get hot safely. It will dissapate roughly 30 Watts when in use.
Surplus electronics shops would be the cheapest source.
Or rebuild the vacuum motor.
Old Jan 7, 2013 | 09:45 PM
  #69
jmadsen's Avatar
jmadsen
Originally Posted by bobj49f2
That's funny
Bob; are you sure that pot is to scale, or the correct size? its definitly the wrong color! looks like a Pooh pot. ya know a hunny pot full of hunny....
anyway. this has been a timely discussion as i am getting ready to reinstall my wiper motor in the F6 and probably need to know all this also.
so can anyone point me to a thread that tells me what I need? wait, what do I need?
sorry i couldnt resist.... just messin.
Ive got extra 6 volt wiper motor assemblys plus an aftermarket 12v setup from ??? that was in a parts truck. ill probably just use that.
Barney58F100
Jan 7, 2016 06:56 PM
Bluey Zedoff
Australia Chapter
Dec 21, 2014 02:15 AM
HILLBILLY BOB
Dec 4, 2009 07:54 PM
shelby1965367
23
Jan 31, 2009 08:14 PM
Bikewrench
20
Jan 10, 2007 10:09 AM
