Electric wiper
You can see where my bracketry and and dash have been cleverly smoked open by a previous owner
Well I have spent the morning trying to make this idea of mine for the wipers work and I can clearly see that it will not, when they initially designed this wiper set-up they make it so compact for the reason of there just being no room under there. I am not going to butcher the truck to make something work and at this point my time and what I know will be the end result will satisfy me less than the feeling of having the original equip. re-worked.
If the flip up cowl vent was not in the way than maybe it could happen but without butchering that and maybe some braces and vents under there it just is not going to happen.
One thing I just learned that I thought was interesting is that in 52 electric were an option, not alot of trucks came with electric, most were vacuum. I thought you could buy an electric conversion kit which meant that I would remove my 6 volt motor from my assy and then place a 12 volt in its place.
I was wrong, the kits being sold are to replace the vacuum set-up and come with all new brackets/linkages ect.
I like this even less, there is nothing wrong with the set-up I have, it looks like new and I am sure has seen very little use. I am not going to shizcan it and put in its place an aftermarket wiper kit which I am sure will have to be made to fit and may look hokey to me every time I crawl under the dash.
I am going to look into other alternatives, the aftermarket kits can be had for about 200 bucks, I would rather put the 200 bucks into having my motor re-wound if I knew it were being done right and would last as long as I needed it.
If anyone knows of a place that does this sort of work please let me know, I am not having any luck here locally.
I am going to ask for some advice on this on the bullnose forum as well, there are some electrical geniuses over there as well. Thanks
Once you get it running you'll find that the real problem is the splined hubs the wiper arms attach to. They slip on the pivot stems. Dennis Carpenter is the only source for new splined hubs and he wants $40 EACH. I'm sure the new ones slip as much as the old ones. Now maybe you see why $300 for a brand new system isn't out of line?
Besides the Jeep and Girling cable-drive options mentioned here, past threads have described using the older VW Beetle systems. They are all out there, use Advanced Search on this forum to find them.
As far as the wiper motors go yes there is alot of info avail for the 48-50 and the 53 and up but I have read time and again that the 51 an 52s are the lone rangers, I could not find any posts that anyone had made where they had replaced their existing 6 volt wiper assy with anything else other than the ready made kits. If you are able to find anything and post a link than it would be appreciated.
I do not think I will have a problem with hubs or what not, the truck has seen very little use, things are just not worn out on it.
I did find mention of a VW wiper motor being used but the post just mentioned a prior post and gave no details, an advanced search of VW wiper motor was useless.
I have tried and will continue trying the advanced search deal using different keywords. If the info has been already discussed and a usable solution has been already reviewed than please copy and paste the link here so that we can see it. Thanks
Well in this particular case, what you read is wrong. Albuq F-1 is one of the absolute best on this forum about this subject and many more. Any wiper setup that will fit a 48-50 will indeed fit a 51-52, but not always vice versa due to the bracing under the dash. The guys on this forum have been fooling with these trucks for a very long time. They know what they're talking about.
postin' fool1952 Ford F-Series Pickup
Quote:
Originally Posted by Julies Cool F1
Hi Kevin,
I took out my 6 volt electric wipers (my truck was produced with a 223 IL6 electric wipers was an option with the 6 - the 239s had vacuum wipers) ........
FYI - electric wipers were an option on all '51 - '52's. Mine came with the electrics and a V8.
I've long had a plan to adapt a common GM, Ford, or Chrysler wiper assembly to my, to get all the features (I'm sure that's what Newport does). If you stick with the stock wiper pivots and the linkage arm that's attached to them, you are really limited. The linkage arm on the stock pivot is very short because of a dash brace and the fresh air cowl vent that run right across that area. I've given up on that idea and will likely use the Lucas cable-drive type, adapted from an MG/Triumph/etc. But I only need wipers about 2x a year, it isn't high on my list.
This was your idea, this is my idea now, you say here that you gave up on the idea because of linkages, cowl vent ect, this was also my findings and I stated these a few posts back, have you since then found a usable solution, if anything from 48 -52 are the same and you were looking to do this conversion back then than why give up on it?
Is it just the resistor that you have now found to work?
Roast em' if you got 'emGarage is empty, add now Join Date: Mar 2005
Keep in mind that the 48-50 trucks have different linkage than the 51/52 trucks. On the 48-50 trucks (either with single or dual wipers) the wiper motor is mounted on the drivers side right at the stalk and not in the center of the dash.
Bobby
__________________
I have done searches using what key words I could come up with and have had no luck.
I'd guess the whole lot would cost less than a Benjamin at a self-serve wreckers....Spend a half hour pulling one out of a car, and you should see how they work!
Granted, I've never done a step-by-step tech article, but if you cant figure it out from my pix, you're likely not capable of installing an "off-the-shelf" kit either?
Easier to look for a part when I have an idea of specifically what I should be looking for, thanks again
