Flathead information sources
Old Jan 6, 2013 | 08:28 PM
fatfenders's Avatar
fatfenders
I am starting the research for my next project. It will be a 48-50 F1 with a flathead V8. Most of you don't know me at all as I have been absent from the forum for 5 years or so. I have built many modern era SB and BB engines in all the flavors (Fords, Chevy and Mopar). I have never laid a wrench to a flatty and it is time. I am a generally not satisfed with stock HP levels so this build will not be confined to stock parts. I am so new at this I don't really know where to start doing my homework, but I guess my questions are ....
1. What websites are good for a flatty information primer?
2. Reliable vendors for rebuild and speed parts?
3. ANY advice for used flatty engine shopping appreciated.
thanks
Old Jan 6, 2013 | 08:33 PM
52 Merc's Avatar
52 Merc
The best flathead Ford forum in the world is here...
Ford Flathead V8 .. 1932 thru 1953 • View forum - Welcome To Our Forum
But you'd better hurry as the guy who's been running it is retiring and pulling the plug on the deal at the end of the month. Hurry and read all there is to know about flatties before it's too late.
Old Jan 6, 2013 | 08:38 PM
bigwin56f100's Avatar
bigwin56f100
Hasnt been here for 5 years and your last post was # 5,000!
Old Jan 6, 2013 | 08:43 PM
GB SISSON's Avatar
GB SISSON
Dave Tatum, Tatum Custom Engines. Lives about 20 miles away on the mainland. High horsepower, hi-tech flatheads... parts accessories, blocks and cranks. Been to his place. An ancient chicken coop for storage, filled to the rafters with good flatties. Or call the guy on the next page here. His post is called merc flathead I think......4" merc crank is a great start in making hp.
fatfenders's Avatar
fatfenders
I used to be the chatty type I guess?
I checked that site 52Merc, I can't even register there anymore so I guess I better get my reading in now.
Old Jan 6, 2013 | 08:50 PM
fatfenders's Avatar
fatfenders
Sounds like a guy I wish I lived closer to. I will probably have to buy an engine more local to get my feet wet. I know the used flatty buy is very risky. And the 4" stroke will probably be a minimum, after I research the downside to going farther than that.
Old Jan 6, 2013 | 08:59 PM
GB SISSON's Avatar
GB SISSON
Yeah, they grind the 4" crank off center to get 4 1/8 (or more), but then the journal is smaller dia, and we know where that leads.......
Old Jan 6, 2013 | 09:16 PM
South of BC's Avatar
South of BC
Could you settle for a 6 cylinder? Another forum member is looking to find a home for one:
https://www.ford-trucks.com/forums/1...-49-f-1-a.html
FORD flathead 6 w/3 speed
Old Jan 6, 2013 | 09:31 PM
fatfenders's Avatar
fatfenders
I am assuming my parts options are better with an 8, but I much appreciate you taking the time to post that link.
Old Jan 6, 2013 | 10:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, the Flathead Forum is shutting down end of month, but the TechnoSite will remain up: Techno Source for the 1932 thru 1953 Flathead Ford Lots of good reading there. There are also lots of good books on building a flathead. Most tend to lean towards the common modifications for hot rods, tho.
That leaves FTE, the HAMB, and the Ford Barn as primary resources. Most of the answers you'll need can be found with searches.
Old Jan 6, 2013 | 10:06 PM
85e150's Avatar
85e150
Manifold comparison. Scroll to the bottom for test engine info and source:
Flathead Ford Intake Manifold Smackdown - Hot Rod Magazine
Old Jan 6, 2013 | 10:07 PM
4tl8ford's Avatar
4tl8ford
I could become a mother of another flathead 6 - I'll give the cl list number tommarrow
Old Jan 7, 2013 | 06:52 AM
fatfenders's Avatar
fatfenders
Thankyou! That article was a good read and exactly the sort of info I need right now.
Old Jan 7, 2013 | 07:00 AM
4tl8ford's Avatar
4tl8ford
Ford Flathead Engines - VanPelt Sales, LLC
Old Jan 7, 2013 | 07:02 AM
fatfenders's Avatar
fatfenders
Thanks, I was finding a bunch of dead BB forums with most of my searches. The FTE flatty forum is really slow too.
