Keyless Entry Question
Old Jan 2, 2013 | 06:44 PM
Mark Alligood's Avatar
Mark Alligood
Question Keyless Entry Question
Is there a fuse for the keyless entry on a 99 F350? One minute mine was working and the next it is completely dead. Anyone???
Mark
Old Jan 2, 2013 | 07:03 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Check your remote battery? Just a thought..
Old Jan 2, 2013 | 07:07 PM
hammer65's Avatar
hammer65
You might try here.
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Jan 2, 2013 | 10:26 PM
cutlass's Avatar
cutlass
You'll find the fuse for your remote keyless entry inside the engine compartment fuse box at fuse #26.
Drake
Old Jan 3, 2013 | 07:03 AM
howellt39's Avatar
howellt39
X2 on the remote battery. Hope it's that simple for you.
Do you have a second remote? Does that one work?
Simple stuff that I'm sure you've checked, just making sure.
Old Jan 3, 2013 | 10:54 AM
F250_'s Avatar
F250_
I had something similar happen to my 2003 Excursion, and still do not have a solution. I had three remotes programmed and working for over a year, and then one day two of them simply quit working altogether.
I pulled out a spare remote, installed a new battery, and went tried going through the programming routine to get it into service, but the vehicle absolutely will NOT go into the programming cycle. Funny thing is that at the same time, the numeric keypad on the door will no longer unlock the doors either... it will lock them, but not UNlock them.
I am left with only one remote which still works today as well as it did three years ago. Fortunately, since it has the chipped keys and I do have several of them available, I can still have multiple sources for getting into the vehicle.
BigJake34452
Dec 16, 2008 09:33 AM
christoph
Oct 5, 2007 08:35 PM
EaTmYtAiLpIpEs
Sep 19, 2007 10:23 PM
jax97f250
Dec 30, 2006 08:20 PM
Poggin
1983 - 2012 Ranger & B-Series
Mar 15, 2002 11:40 AM
