keyless entry quit
Old Dec 9, 2008 | 03:11 PM
BigJake34452's Avatar
BigJake34452
keyless entry quit
the keyless entry in my 00 f-250 quit working. i have 2 remotes both worked on that thing at autozone. there must be a fuse or something, anyone know what it is?
Old Dec 9, 2008 | 04:48 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Can you hear it working, or do the actuators not make any noise at all?
Old Dec 9, 2008 | 06:51 PM
clintbonnie's Avatar
clintbonnie
Check under the hood fuse box... If it the same as a 99, it is the 3rd one down from the back, in the middle row..20amp fuse.
Old Dec 9, 2008 | 09:17 PM
BigJake34452
nothing works at all, just quit out of nowhere, i will try what clintbonnie suggested
Old Dec 9, 2008 | 09:20 PM
STROKIN'IT7.3
That was my next thing was the fuse. ... the actuators have tendency to stick hence why i asked. Let us know what the fuse shows (also refer to your owners manual for the proper fuse location)
Old Dec 9, 2008 | 09:23 PM
BigJake34452
will do, BTW, that santa pic is freakin me out.
Old Dec 9, 2008 | 09:27 PM
STROKIN'IT7.3
Haha my fault, dare to be different i guess? Idk lol
Old Dec 9, 2008 | 09:40 PM
BigJake34452
lol, yea its a good one
Old Dec 10, 2008 | 08:49 AM
BigJake34452
fuse is good, how do i check those actuators?
Old Dec 16, 2008 | 08:03 AM
BigJake34452
anybody have any advice before i rip my door apart lol
Old Dec 16, 2008 | 08:55 AM
F350-6's Avatar
F350-6
How many doors do you have? Push the lock/unlock button on the door and see if the locks work. Unless you've had problems with some of the doors not working for a while, it would be unlikely that all the actuators failed at once. If you do hear a clicking type sound where it sounds like the door locks are trying to do something when you hit the switch on the door, then it does sound like an actuator problem. No noise at all sounds more like a fuse.
I'd try a test light and check all the fuses to see if you have any bad ones.
Old Dec 16, 2008 | 09:04 AM
BigJake34452
it has 2 doors, it is a manual lock but has keyless entry. i swapped the fuse with a good one and it still didnt work, but im not getting any noise at all from the doors.
Old Dec 16, 2008 | 09:19 AM
F350-6's Avatar
F350-6
So then this is an aftermarket system? If so, it will likely have it's own inline fuse wherever they tied into the power.
Old Dec 16, 2008 | 09:23 AM
BigJake34452
dang ill just have to look around then, thanks for the help
Old Dec 16, 2008 | 09:33 AM
BigJake34452
well that was easy lol, found the fuse, it was loose. works great now, thanks again!
fordguy2236
1997 - 2003 F150
Jul 13, 2013 09:49 PM
97e150vanman
Sep 19, 2010 10:03 AM
panchoclark
Jun 2, 2008 01:09 AM
buckdodger
Electrical Systems/Wiring
Dec 15, 2004 08:50 AM
Aug 25, 2002 10:40 PM
