Sponsored by: Real Truck
Keyless Entry
Old Sep 19, 2007 | 08:37 PM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
Keyless Entry
I have a question. I didn't get a remote for my truck when I got it but it is hard to believe this thing doesn't have it. Is there somehow I can test to see if it has it? And how can i test for it or look for it.
Old Sep 19, 2007 | 08:39 PM
v10lampert's Avatar
v10lampert
there should be a relay in the fuse panel either under the hood on under the dash that is for the keyless entry system. if there is a fuse there then you should have it if not i dont think you do
Old Sep 19, 2007 | 10:23 PM
aldridgec's Avatar
aldridgec
cycle your ignition switch 8-12 times with the door closed. If the locks cycle then you have keyless entry. If you had a keyfod, you would press a button and the locks would cycle again programming the remote.
