I need to change oil in 3 rigs today............oooh-rah!
BTW.........Don, how long do you need to use the zinc additive with a new cam, just break-in, or for life since they quit putting zinc in oil? (Thanks EPA)
Zinc was an anti-friction modifier that was in older oils. The EPA mandated it's removal. It's not a problem for engines with roller cams/rockers, but causes premature wear on older style lifters causing premature cam/lifter wear. Some oils are still made with the Zinc in them, mainly oils for diesels, additive zinc is available separately and is the thing to use in our older engines.
I can't find oil that has zinc in it anymore..........Remember, we had a member who no longer posts here, have a brand new engine trashed because the cam came apart from no zinc in the new oils.
I have been buying the additive at Knecht's since I built the new 2.8 in the Ranger, and adding it to the oil.........thought after break-in you could stop?
Here ya go Dave. And yes my Rotella is still on the list!
No catalytic converter, standard lifters, needs Zinc!
Sorry Dave........
Well, I use Castrol, so it's on the list of .12 Zinc content, so that makes all good.
The 2.8 is most definitely going to stay on the additive, since it is a solid lifter, flat tappet-cam engine, (might as well play it safe)............Catalytic converter was "lost" on some trail about 25 years ago.
