Changing fuel filters
Old Dec 31, 2012 | 09:35 AM
big-head's Avatar
big-head
I want to change both fuel filters. 2007. 6.0. After changing do I simply just start the truck and let it idle. Will the engine digest the air okay ??? Or is there a way to purge the air.... Just bought the truck so I'm new to it.
Also how often do I change the oil and filter ???
And what about the fuel filters ??
I don't pull much with it. I'm not a hard driver.
Old Dec 31, 2012 | 09:37 AM
69cj's Avatar
69cj
Do 3 key on/ key off cycles for 10 secs. each to purge the system. Then start and you should be good to go. Make sure to use OEM only filters and caps.
bismic's Avatar
bismic
Check out the Tech Folder - lots of stuff like this in it.
You need to cycle the key on and off a few times to purge the air out - it is described in the thread in the Tech Folder.
oops - better answer Mike!!
Old Dec 31, 2012 | 11:06 AM
gwg42's Avatar
gwg42
One of several pieces of good advice from this site was to use the proper size sockets to remove the filter caps. My previous filter changes were always done with dealers, both caps were on extremely tight. Sprayed with penetrant and let sit for a while. My truck is a 4x4 so everything is tight on the rail filter.
Old Dec 31, 2012 | 11:32 AM
brapom's Avatar
brapom
cycle key 3 times then start all should be well. ck for leaks after 5 min of road test. Be carefull when removing and installing the water drain plug. There is a updated plug you can get from your local dealer Happy New Year
Old Dec 31, 2012 | 01:14 PM
big-head's Avatar
big-head
Water drain plug ??
Old Dec 31, 2012 | 03:32 PM
bismic's Avatar
bismic
The primary fuel filter (the HFCM) has a drain plug for removing water. You don't empty the water reservoir by just changing the filter.
Old Dec 31, 2012 | 04:03 PM
big-head's Avatar
big-head
I will look for it. Does it also drain all the fuel. To ad in staying dry when removing it while laying on ur back. What socket size is it.
Old Dec 31, 2012 | 04:14 PM
npccpartsman's Avatar
npccpartsman
No it doesn't drain all the fuel and it's a 6mm allen wrench UNLESS it's been upgraded to the new style drain plug
Old Dec 31, 2012 | 04:45 PM
big-head's Avatar
big-head
Thanks. If it has been changed what will it be. Do I need to pull the plug from time to time and drain.
How often do I need to change the oil and filter and the fuel filters.
Old Dec 31, 2012 | 05:05 PM
bismic's Avatar
bismic
Tech Folder:
https://www.ford-trucks.com/forums/3...ch-folder.html
HFCM Filter Change and Fuel/Water Separator Drain Procedure
FUEL/WATER SEPARATOR DRAIN PROCEDURE
Upper Fuel Filter, Engine
Changing Upper Fuel Filter
HFCM Water Separator Drain Plug Upgrade
PLUG INSTALL
Old Dec 31, 2012 | 05:37 PM
big-head's Avatar
big-head
Originally Posted by bismic
Tech Folder:
PLUG INSTALL
Thanks very very much for the links.
Old Dec 31, 2012 | 06:45 PM
william_04_x's Avatar
william_04_x
Here's a tip: If you've bought Motorcraft filters, don't jam your finger through the plastic wrapping of the little filter to open it up. It's got some sharp teeth in there, and it bites.
Old Dec 31, 2012 | 07:32 PM
big-head's Avatar
big-head
What's the oil filter ford part number ?? I have the fuel #'s
EMC V10 X
Dec 7, 2014 07:09 PM
tompc59
Nov 11, 2012 07:30 PM
backwoodsgoop
Apr 9, 2010 12:34 PM
bdb2047
Aug 14, 2008 12:49 PM
fordsd350
6.4L Power Stroke Diesel
May 4, 2008 03:53 PM
