HELP with Fuel/water separator plug
Old Dec 31, 2012 | 06:00 PM
RideDiesel88's Avatar
RideDiesel88
Well its stripped out. Im sure its happened to many but i dont really know how im gunna get it out. I already tried to JB weld a 6mm wrench in and no luck at all. I also tried to jam a 7mm and the size between and luck fittin it in. Im thinkin a torxbit might be able to get in there. Anyone had this problem? Any clue what to do? Thanks for any replys
Old Dec 31, 2012 | 06:33 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Many have had this issue. I would have suggested the JB Weld.
Sadly, a lot of times it will take buying a new manifold cover for it.
Old Dec 31, 2012 | 09:44 PM
cheezit's Avatar
cheezit
drill bit and extractor if your lucky. if not new pump manifold
Old Dec 31, 2012 | 10:14 PM
PowerItUp's Avatar
PowerItUp
Just went thru this. Like you, nothing worked until I decided to really go at it. I took a drimmel and made a horizontal cut in the plug almost all the way accross. Next took a punch as close to the edge of the plug as I could get it in the groove I cut and started pounding with a hammer in a counter clock wise hit and spraying with some PB. It was a tough angle with the shaft right there. Kept at it and it finally broke loose. Don't know if it will work for you but worth a shot before replacing the entire thing.
brandon.edwards
May 29, 2013 11:47 PM
firemanpat29
Aug 9, 2012 10:57 PM
raptor2005
Jan 25, 2010 04:39 PM
jaybe
Jul 24, 2007 04:21 PM
jules
Jan 9, 2001 06:31 PM
