Tryng to pull codes, cannot find STI connector.
Old Dec 29, 2012 | 02:55 PM
bikeymikey's Avatar
bikeymikey
Hi!
I'm here trying to diagnose a cranks/no start condition. First thing to do is pull codes, right?
I can find the self test output connector (the bigger one) but no sign of the STI connector. Does someone here have a pic of their connectors they can share? I'm working on my 89 f350 FI 460.
I did a search in this forum, but it looks like the relevant pics posted by subford have been deleted.
Thanks! Mike
Old Dec 29, 2012 | 03:35 PM
Lazy K's Avatar
Lazy K
Fuel Injection Technical Library » How To Run a Self-Test Should be like this. Should get 2 digit codes.
Old Dec 30, 2012 | 01:01 PM
bikeymikey's Avatar
bikeymikey
update on the crank/no start condition
well, i never got to pulling the codes. i decided to just check the fuel system, since it seems to be widely accepted that a crank/no start is 80% of the time that.
tested by checking for juice to the fuel pump relay, no dice. so on to the eec relay, no juice there either. the website i was following to do this diagnosis states that if that happens, most of the time it's an ignition switch issue.
that was it! i climbed into the cab and turned the key and pushed the actuator rod in a bit more and she fired right up!
Part 1 -4.9L, 5.0L, 5.8L Ford Index of Articles.
i guess that tells me that i'll probably have to take care of the ignition acuator rod. luckily there's this forum to guide me through that.
thanks, all
Mike
Old Dec 30, 2012 | 03:19 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/8...-actuator.html Here is a link to a good writeup by jas88 on replacing the actuator.
However the ign switch is bolted to the top of the column under the dash and may just need adjusted.
Lzryde
Mar 24, 2015 08:38 AM
PEG
1997 - 2003 F150
Oct 20, 2014 11:54 AM
mike_23us
1983 - 2012 Ranger & B-Series
26
Dec 30, 2005 04:50 PM
mudbone1979
Bronco II
Sep 8, 2004 08:24 PM
AMDAP
1978 - 1996 Big Bronco
Oct 27, 2003 06:15 PM
