1978 - 1996 Big Bronco
codes and no starting
Old Oct 27, 2003 | 05:24 PM
AMDAP's Avatar
AMDAP
hey everybody...I pulled the codes again and got codes 626 629 and 636. I still can't get this stupid Ford started. I have new plugs, wires, cap, rotor, and fuel pressure regulator. It kind of sounds like it is trying to start. It just isn't ever strong. What do the codes mean? Why won't it start? Why did I ever buy a ford?
Thanks a whole bunch guys!!
Old Oct 27, 2003 | 05:44 PM
96bronco58's Avatar
96bronco58
626 is coast clutch solenoid circuit failure 629 is converter clutch control circuit failure and 636 shows TOT sensor voltage out of self test range.
Old Oct 27, 2003 | 05:50 PM
DW2455's Avatar
DW2455
I cant find those code? maybe someelse knows what they are. Have you check the relay for the ecm? and when you switch the key on do here the fuel pump buz for a breif second? DW
Old Oct 27, 2003 | 06:01 PM
AMDAP's Avatar
AMDAP
sorry about that...I knew what the codes were, I just don't know what they mean. Fuel pump is working. How do I check the relay for the ECM? Would that get progressively worse?
Old Oct 27, 2003 | 06:15 PM
DW2455's Avatar
DW2455
The relays should be over on the driverside fender well, but i would pull a couple of spark plugs and check for fire, gas,fire,and air and it will run. DW
Sleepy445FE
Apr 30, 2023 07:39 PM
jdog59
1997 - 2003 F150
Aug 27, 2013 07:58 PM
Towerrider87
Jul 11, 2013 04:50 PM
'86_150
Aug 26, 2007 11:38 PM
stroker04
Jan 5, 2007 09:52 PM
