1991 2.3L Ranger 2wd-----okay im totally confused im not getting any power down to my fuel pump the wirings good i check the relay it good i ran a jumper wire within the relay connection and i get the pump to run the pressures only 22psi i got a new pump and put it in now i got 40psi but still all the engine will do is crank crank and crank . iv put a new fuel filter on so thats not the problem and iv got spark im completly stumped please help
mike
Look on the passenger floorboard of your truck, underneath the dash, probably a little behind the carpet. See if you're fuel pump cutoff switch has been tripped. That is immediately what I think and I bet is the problem.
the cutoff switch was the 1st thing I checked. And about the codes i have a scanner and everytime i try to retrive the codes it says it has an error. the connections between the truck and scanner are fine and iv repeatidly tried to pull the codes but same thing. ERROR
A bad EEC relay can do the same thing too. It can cause the PCM to not have power to it which makes it not fire the injectors, not turn on the fuel pump etc.
I haven't worked on an older Ranger in a long time but I think the EEC relay should be on the passenger's side of the engine compartment, near the heater blower motor. There should be 2 relays there. One with a green connector for the fuel pump and one with a black or brown connector for EEC.
I think
Hello iv posted this topic before but i cant figure it out, i have a 91 ranger 2.3 L 2wd. when i goto start it all it does is turn over iv checked everything i know to check. the fuel pump is good, the relay is good the wiring circuit is good but i dont know. my fuel pump doest kick on at all unless i run a jumper wire withing the relay connection and even with the pump running it wont start. the EEC relay is good. could it be the computer or not. i really would like to fix the truck but i have no clue as what it is any suggestions advice any thing would help. and the fuel pump cutoff switch is the first thing i checked so thats fine.
I thought you said you had 40psi fuel pressure in your other post? Is that only when you run a 12V hot wire to it?
Did you do any work on the truck before all of this started or is it totally out of the blue?
If you had the motor apart before all of this then check your firing order. I know it sounds stupid, but I've spent hours before trying to figure out why my car wouldn't start before realizing I had some wires going to the wrong plugs.
It seems unlikey your computer would fail unless the vehicle flooded.
After changing the filter and pump, you would have a LOT of air in the fuel lines. You can just crank it until it starts if you choose. That might be your problem, just a lack of fuel.
It will probably start then idle really low and struggle until a constant fuel supply gets to it, then it'll run just fine.
