when i switch the transfer case shift motor to high does the shift motor keep it lock in high, and say would a weak shift motor cause it to "pop" in and out of 4wd
just trying to figure how all this works
I'm still having a popping transfer case
I know about tire sizing, not driving on dry payment with 4wd,etc
thanks chad
2001 sport trac 1354 bw
does not have awd, auto 4wd
just 2wd, 4wd hi and 4wd lo
does the shift motor keep it locked in 4wd or what keeps the transfer case locked in 4wd
when my transfer case pops in 4wd under load it will go into 2wd, but when you let off the throttle it will go back into 4wd
i can drive in 2wd all day long no noise whats so ever
any help is appreciated thanks chad
