Dash lights and signal light
Old Dec 15, 2003 | 08:59 AM
isaz's Avatar
isaz
Thanks in advance for all your help you guys have been
great help.
I have a 79F250 4x4 crewcab i just recently purchased.It
needs minor work and i am going crazy with the interior
dash light keep blowing a fuse.Once i pull the light
swicth the fuse blows could it be my light swicth it is real hard to turn for the dome lights.
Problem #2 is all my parking lights work and signal lights
except the drivers rear.the brake and signal light do not work on my driver side.The signal light on the dash works for the right side but not the left.I replaced the bulb checked the ground and still no luck.I replaced the flaser as well i have not changed the hazard flasher.Does anybody have any suggestions..
Thanks Again....
Old Dec 15, 2003 | 01:18 PM
dfisher1's Avatar
dfisher1
isaz,
This is a common problem. The rear light sockets are subjected to a lot of vibration which eventually renders the sockets usesless.
Go to your auto parts store and buy a replacement socket. Secondly, CLEAN the gorund! The grounds are always rusty or painted and can give you fits during diagnosis. After you've done this, everthing will work fine.
KingFisher
Old Dec 15, 2003 | 01:28 PM
isaz's Avatar
isaz
I forgot to mention this is a flatbed truck and the lights are attached via 2 bolts i cleaned them up real good and took a grinder to where they bolt on i did'nt clean the ground to the frame though.would this also cause my dash lights to go out as well.I thought it might be the turn signal switch.i will try to clean the ground and see what happens.I will try to replace the sockets as well or do i have to change out the whole light.
Old Dec 15, 2003 | 01:33 PM
dfisher1's Avatar
dfisher1
isaz,
Often enough the sockets are modular on these after market light assemblies. If you can change out a socket, hang on to those lenses, there rare! Generally, if the dash turn light is on constantly,(when headlight switch is on), this means the ground is bad or bulb is burned out. If the dash turn light is out, you probably have a bad dash light. Do you know how to get to a dash light?
KingFisher
Old Dec 15, 2003 | 01:51 PM
isaz's Avatar
isaz
Behind the bezel light right?Would that cause the signals in the drivers rear not to work or the stop lamp.And would this also cause the dash lights to keep blowing the fuse?
Thanks alot
Old Dec 15, 2003 | 02:07 PM
dfisher1's Avatar
dfisher1
isaz,
If your blowing fuses, you've got a hot wire to ground. Most likely, its you head light switch. If the power is going through a bulb, then its not shorted. If the bulb won't light, then the short is before the bulb, right? Have you inspected your harness? Do a quick inspection and see if you can find a bare wire. If the harness looks good then you'll have to remove the dash and inspect the harness behind the gages and at the headlight switch. if you have an extra headlight switch, swap it and see what that does for you. I'd go to the junkyard and pick one up at a discount, if you know what I mean.
KingFisher
Old Dec 15, 2003 | 02:28 PM
isaz's Avatar
isaz
I will try and replace the headlight switch this weekend by the time i get home it's dark and cold i have a donor truck to pull it off of.Do you still think i have a ground problem
in my rear?
Thank alot for your input.....
