Electrical Problems
Old Feb 22, 2003 | 01:09 AM
loserpdenton's Avatar
loserpdenton
Question Electrical Problems
I recently bought a 1975 Ford F100 w/302 and replaced the tail light bulbs thinking that they were bad, but it turns out that the bulbs are not at fault:
1) Driver's side tail light does not work, brake light does
2) Passenger side brake light does not work, tail light does
3) Neither back up light works
4) One dash light works, the right turn signal arrow, but this stays on all the time when the headlights are on.
Both headlights and parking lights work along with all of the side marker lights.
I haven't looked into the dash light problems yet, but what are the steps I need to take to correct these problems?
Old Feb 22, 2003 | 01:33 AM
Mil1ion's Avatar
Mil1ion
Electrical Problems
1) Driver's side tail light does not work, brake light does.
check the entire wiring circuit (from just under the bumper left side) to just that light bulb filament.
2) Passenger side brake light does not work, tail light does.
Check to see the brightness of the bulb filament ,to make sure they aren't cross-connected first.
Then get back with the info
Probably the combination neutral safety <>B/U switch,
Attach 12 v power to the wiring to the bulbs to check.
More than likely a short in the running light circuit that is shorting to the turn light circuit,this will illuminate the Trun signal dash light
I assume you're talking baout the front park lights?
Excellent
You will need some sort of 12v power supply(even a 25 ft wire from the battery) to attach to wires near the bulbs or wiring connectors & See above
Old Feb 22, 2003 | 04:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
Electrical Problems
Sounds like a possible case of bad grounds too...
jerrysrios
Electrical Systems/Wiring
91
Feb 18, 2025 03:12 PM
72Blazerod
Mar 11, 2016 09:26 PM
BlakePopovich
Jul 25, 2011 10:00 AM
54Guy
1978 - 1996 Big Bronco
Oct 25, 2004 08:27 AM
