In the Ditch!
Old Dec 17, 2012 | 10:39 AM
Buck1961's Avatar
Buck1961
In the Ditch!
Hi everyone and anyone who can help! I have a 2001 7.3 Lariat Diesel Manual Transmission Dually that I backed off of the drive way. I dropped the rearend off of the edge of the drive hard on the chunk and yanked out of the ditch with tractor. Drove truck about 1/2 mile and it starting shutting down as if it was not getting fuel. Turns over but won't crank. Check fuel shutoff switch. Any help is appreciated!
Old Dec 17, 2012 | 10:47 AM
snakedoc's Avatar
snakedoc
did you check the tank to see if it was busted?
do you have fuel in the bowl?
Old Dec 17, 2012 | 10:52 AM
Buck1961's Avatar
Buck1961
Tank is not busted. There is fuel in the bowl. Also the inertia switch not been tripped.
Old Dec 17, 2012 | 10:54 AM
howellt39's Avatar
howellt39
Agreed, check the underside of the truck for impact damage to the fuel tank or rail-mounted pump/lines.
Old Dec 17, 2012 | 10:58 AM
Buck1961's Avatar
Buck1961
Checked those as well. Everything appears to be intact.
Old Dec 17, 2012 | 11:11 AM
SkySkiJason's Avatar
SkySkiJason
Open the water drain valve on the fuel filter. After the bowl empties (about 10oz or so), turn on the ignition and observe flow. The pump will run about 30secs and should nearly fill a 32oz bottle.
Fwiw, I always put a piece of hose on the drain line tubing so I can collect and inspect the contents of the fuel bowl.
Meanwhile, does the SES lite come on and stay on when key is in the on position? Have you checked ALL the fuses (under dash AND under hood)?? Does the tach 'bounce' while you are cranking? Is engine full of oil?
Also, this engine WILL NOT start if the PCM sees less than 10.5v while cranking. It will 'turn over' just fine, but never fire... Make sure batts are fully charged now that you are trouble shooting.
Old Dec 17, 2012 | 11:24 AM
Buck1961's Avatar
Buck1961
Thanks for all of the suggestions! Going to check the latest ideas right now. Will let you guys know the results. Thanks Again!
Old Dec 17, 2012 | 11:59 AM
SteveH-CO's Avatar
SteveH-CO
A buddy of mine hit an offroad bump, and immediately started having running issues - it was the UVCH - and he used the FTE directions to do the 50 cent mod and all was well. Perhaps you bumped loose this wiring, or some other. I guess I'd check fuses if nothing else works for you.
Old Dec 17, 2012 | 01:30 PM
Tugly's Avatar
Tugly
Same thing happened to another member while on vacation - UVCH... but the engine started on the driver side (very rough).
Old Dec 17, 2012 | 01:39 PM
PaysonPSD's Avatar
PaysonPSD
If you are low on fuel and not on level ground that could be a problem, especially if the in tank pick up foot got damaged. They can rot and fall off all on their own.
Old Dec 17, 2012 | 02:42 PM
Buck1961's Avatar
Buck1961
Thanks for all of the Help!
So I topped off the oil (which was low from the dealership) and drained the fuel line. It appears that maybe there were some air in the line. So far so good... Hopefully this has repaired the problem! Thanks again for all helpful hints!
Old Dec 17, 2012 | 03:01 PM
Buck1961's Avatar
Buck1961
Raymond Hines
Oct 21, 2017 01:42 PM
94red1ton
Nov 2, 2010 02:52 PM
gimmeice3
1978 - 1996 Big Bronco
Nov 9, 2006 09:14 PM
western star
Aug 8, 2006 05:08 PM
4x4man514
Oct 3, 2004 04:23 AM
