1978 - 1996 Big Bronco
fuel tank
Old Nov 8, 2006 | 06:09 PM
gimmeice3's Avatar
gimmeice3
Question fuel tank
fuel tank rusted out so i dropped it and switched all the guts to the new one , wanted to know if there is anything i should worry abvout doiong before i put the new one in , also the manuel i have says to reset the inertia switch where and what is that ?? an how do i reset thanks - matt 1987 5.0 bronco
Old Nov 8, 2006 | 08:01 PM
gman88's Avatar
gman88
Nothing I can think of other than replacing the clips for the fuel lines, they can get damaged when removed. I did not have to reset the inertia switch as stated in the procedure and it worked just fine.
Old Nov 8, 2006 | 08:29 PM
andym's Avatar
andym
Unless your inertia switch got tripped because of an accident, I have no idea why they would tell you to reset it. You don't need to do anything else, except cycle the fuel pump on and off a few times before you start it. It'll make starting it easier.
Old Nov 9, 2006 | 09:14 PM
gimmeice3's Avatar
gimmeice3
thanks for your feedback i did in fact replaqce the clips we ll see how everthing works out
Glenn Blackwell
Aug 6, 2014 05:15 AM
Showtime
6.4L Power Stroke Diesel
Nov 2, 2007 04:40 PM
yoda
Apr 25, 2006 12:22 PM
Exodus1980
Apr 6, 2004 10:09 AM
TheJag1900
15
Dec 30, 2003 10:05 PM
