Heater anomaly . . .
Old Oct 25, 2012 | 12:28 PM
1'stonraceday's Avatar
1'stonraceday
'01 F350. Winter setting in in the Rockies and am having a strange heater problem.
Engine temp is up and adiquit to heat cab, but cold air is coming out of vents. I've tried rotating the temp control, set it to "medium" heat, then back up again.
Then next time I get in, the heat is coming out. . . . or not. Not predictable.
I've had the truck for 7 years and am very familiar with how the controls work.
As if a valve or vent isn't opening. Are they run by vacuum?
WT*?!
Old Oct 25, 2012 | 01:04 PM
Tailgate77478's Avatar
Tailgate77478
You may have a broken or slightly broken blender door, which is located behind the glove box. Do a search on here on how to diagnose (you're going to need a small angled mirror), and how to fix.
May not be the issue, but...
Old Oct 25, 2012 | 01:39 PM
1'stonraceday
O.K.! I'll try that.
Old Oct 25, 2012 | 02:08 PM
SkySkiJason's Avatar
SkySkiJason
The Lariats and Excursions do have a valve, but it only stops flow from heater core when MAX AC is selected. You can verify the hoses to heater core are getting hot and narrow it down to a blend door pretty easily.
Old Oct 25, 2012 | 04:38 PM
Brother Les's Avatar
Brother Les
Doesn't the door work off of a vacuum? Might have a vacuum leak. Not 100% sure.
Old Oct 25, 2012 | 04:41 PM
Tugly's Avatar
Tugly
If there was a vacuum leak, the vent would go to defrost and just stay there.
Old Oct 25, 2012 | 06:28 PM
1'stonraceday
Good stuff everybody . . . plenty to look at!
Old Oct 26, 2012 | 03:19 PM
1'stonraceday
Maybe it's the actuator?! Any way to test it before buying new one?
Old Oct 26, 2012 | 05:10 PM
BigAlsPSD's Avatar
BigAlsPSD
The temperature blend door is not vacuum actuator, the panel vent control is. The blend door is an electric actuator. I've never seen the electrical portions fail personally, but the square drive or door pin itself I have seen break, especially with them being plastic.
The actuator is pretty easy to get to, behind the glovebox, you should be able to remove the couple of screws holding it in, and try the temp control, to see if the actuator moves, if it does, look at the door itself, down in the hole the actuator connects to, and make sure it's not broken.
Old Oct 26, 2012 | 07:01 PM
1'stonraceday
That's what I'm gonna do!
Old Nov 10, 2012 | 06:47 PM
Tailgate77478
Any luck / update on this issue???
Old Nov 10, 2012 | 11:31 PM
1fixitman's Avatar
1fixitman
He is too cold to work on it LOL. He is probably getting some hot coffee right now.
Old Nov 11, 2012 | 10:51 PM
keith180's Avatar
keith180
I'm dealing with the same issue on my '99 350. I have hot heater hoses, opened up the fan box and watched the blend door move back and forth with the temperature selector. Is it possible to have an intermittant problem with the blend door actuator. Also the a/c comes on with the selector switch in all positions except the first position to the left and the second position to the right. Is that normal or could the a/c be coming on cooling the air. Sorry to hijack the thread but it sounds like the same problem.
Old Nov 12, 2012 | 07:38 AM
Tailgate77478
The issue with the blend door is that typically the piece of plastic gets broken, so the mechanism is turning, but the door doesn't actually move. It's more common that it gets stuck where it is allowing heat in, but sometimes it breaks where it is closed and won't allow heat in. Here's a link to photos, etc.
https://www.ford-trucks.com/forums/1...full-cool.html
If your door is broken, here's the Dorman part:
http://www.dormanproducts.com/p-11567-902-207.aspx
Old Nov 13, 2012 | 04:36 AM
hydro man 17's Avatar
hydro man 17
Yes the A/C is on with everthig except "vent" on my '01 and '02 ranger. It normally runs with the heater and especially the defroster. On defrost so the air goes though air dryer. Otherwise you get warm wet air on your windshield and need to carry a bag of bullduram to clean the inside like I did in my '50 Chevy
