No problem! The breather I have doesn't have the tube for the pcv..but I'm running an offy intake..it has a hookup for a vacuum line straight into the intake. I wouldn't use if for anything else..so could I hook up the pcv to that?
The full intake vacuum port is where the pcv valve is supposed to be connected. The pcv valve always has suction when the engine is running. It is at the rear of the valve cover.
The front hole in the valve cover is for the crankcase breather (filtered intake air). It is best connected to the carb air filter housing. Some use a vented and filtered cap there or you can drill a hole in the air filter hosing and use one of these. Only 2 or 3 bucks and one from a GM comes with the retaining clip.
A lot of this stuff you can find at a junk yard and also a good place to learn where things go.
