pcv needed
Old Dec 15, 2012 | 06:17 AM
68cabby's Avatar
68cabby
pcv needed
Just curious..I just put a breather where the pcv goes..should I put a pcv on?
Old Dec 16, 2012 | 12:15 PM
68cabby's Avatar
68cabby
Just wondering
Old Dec 16, 2012 | 01:08 PM
tiap's Avatar
tiap
Short answer.
Absolutely use a real pcv valve to the intake AND a breather in the front of the valve cover.
There are only pluses no downsides.
Old Dec 16, 2012 | 04:49 PM
68cabby's Avatar
68cabby
No problem! The breather I have doesn't have the tube for the pcv..but I'm running an offy intake..it has a hookup for a vacuum line straight into the intake. I wouldn't use if for anything else..so could I hook up the pcv to that?
Old Dec 16, 2012 | 05:05 PM
tiap's Avatar
tiap
The full intake vacuum port is where the pcv valve is supposed to be connected. The pcv valve always has suction when the engine is running. It is at the rear of the valve cover.
The front hole in the valve cover is for the crankcase breather (filtered intake air). It is best connected to the carb air filter housing. Some use a vented and filtered cap there or you can drill a hole in the air filter hosing and use one of these. Only 2 or 3 bucks and one from a GM comes with the retaining clip.
A lot of this stuff you can find at a junk yard and also a good place to learn where things go.
Old Dec 24, 2012 | 12:24 PM
The Frenchtown Flyer's Avatar
You will have to fatten up the idle circuit to use the PCV valve.
Old Dec 24, 2012 | 01:14 PM
68cabby's Avatar
68cabby
So is it needed?
Old Dec 24, 2012 | 02:09 PM
Harte3's Avatar
Harte3
You need crank case ventilation of some kind. The old, polluting road draft tubes are taboo. That leaves a PCV system.
malveaux0089
May 25, 2007 06:22 PM
biz4two
Modular V10 (6.8l)
Oct 28, 2006 11:36 PM
hellraiser
Jul 19, 2004 07:13 PM
Texan1983
Jul 22, 2003 05:24 PM
Jims95Ranger
1983 - 2012 Ranger & B-Series
Oct 5, 2001 11:43 AM
