no PCV
Old Jul 21, 2003 | 08:45 PM
Texan1983's Avatar
Texan1983
no PCV
am i hurting any thing by not running a pcv system? i just have two breathers one on each valve cover. i don't see how i could be, juct needs to be vented right? where would i hook one up if i wanted to? i have an eldbrock intake and holley carb and it doesn't seem to have anymore fittings for a pcv.
Old Jul 21, 2003 | 08:51 PM
woodworker8's Avatar
woodworker8
no PCV
what type of edelbrock intake?
Old Jul 21, 2003 | 09:02 PM
78RangerXLT's Avatar
78RangerXLT
no PCV
man, there should be a a larger vacuum port on the back of the carburetor for a pcv valve, i have a stock motorcraft 2150 and i run pcv on one valve cover and i have a vent breather on the other cover, it helps in the ventilation of the crankcase, thus the name Positive Crankase Ventilation, it serves a purpose, take it easy and drive hard
Old Jul 21, 2003 | 10:33 PM
Torque1st's Avatar
Torque1st
Posting Legend
no PCV
Hook up the PCV system.
Old Jul 22, 2003 | 12:04 AM
Texan1983's Avatar
Texan1983
no PCV
i see alot of engines without it, the only purpose is to vent the crankcase right? breathers do that, the only bad thing i guess would be emissions. but what does it hurt? i thought there was only one eldbrock intake for these trucks? i am pretty sure its a 400
Old Jul 22, 2003 | 12:10 AM
Matts72's Avatar
Matts72
no PCV
Actually it helps prevent blowby. It helps your mileage. It keeps your oil clean longer. On a rebuild it helps the rings seat. its a good setup you should use it.
Old Jul 22, 2003 | 12:11 AM
Texan1983's Avatar
Texan1983
no PCV
well damn now i have to find a place to hook it up! any ideas? where should it go?
Old Jul 22, 2003 | 12:15 AM
Matts72's Avatar
Matts72
no PCV
There is a place on the back of the carb for it. You can also use a manifold vacuum for it too.
Old Jul 22, 2003 | 06:18 AM
Torque1st's Avatar
Torque1st
Posting Legend
no PCV
The PCV valve MUST go to the fitting on the back of the carb in order to spread the load over all of the cylinders. All other vacuum hoses should go to the regular manifold vacuum ports.
Old Jul 22, 2003 | 09:54 AM
Native Gearhead's Avatar
Native Gearhead
no PCV
Ditto on what Torque1st said, and yes you should hook it up; it helps. If you don't have a place for it on the carb, you can get one of those cheesy gasket/adaptor plates (from the boneyard) for the EGR line for the older trucks, and use that for the PCV instead. You can use the "open" breather cap instead of going back to the air cleaner.
Old Jul 22, 2003 | 05:09 PM
ranger429's Avatar
ranger429
no PCV
i thought the power brake booster connected to the back of the carb?
Old Jul 22, 2003 | 05:24 PM
Native Gearhead
no PCV
Well I don't have power brakes, but the ones I have seen, the PB vacuum comes off the main vac tree behind the carb.
08F1Tizzy
2004 - 2008 F150
Nov 15, 2012 08:41 AM
deyomatic
Dec 17, 2008 07:52 PM
98range
1983 - 2012 Ranger & B-Series
Jul 13, 2007 07:27 PM
dgpruitt
Mar 25, 2005 05:14 AM
gowers
Mar 28, 2004 08:55 PM
