Need help with vin
Old Dec 13, 2012 | 08:42 PM
rjbuningsr's Avatar
rjbuningsr
Need help with vin
New guy here.... MY 1965 standard has a VIN of F10JN648069. It apears that the Original color was single color of Yellow.... Could this be?
Old Dec 13, 2012 | 08:53 PM
garbz2's Avatar
garbz2
It very well could be.
To decipher the color you need to post all the information from the waranty tag on the drivers door.
Garbz
Old Dec 13, 2012 | 10:28 PM
SuperSabre's Avatar
SuperSabre
We can tell you some information based on the VIN: F10 = 2 wheel drive F100 truck. J = 240 cubic inch I6 1V engine. N = built at Norfolk, Virginia. 648069 = built in February, 1965. For more information, as Garbz said, post your warranty tag information.
Old Dec 14, 2012 | 07:34 PM
rjbuningsr's Avatar
rjbuningsr
65 f100 Decoding warranty tag info
Ok I looked at the warranty tag... the words were hard to read with most of the words were washed out. This is what I could make out
Color: 115
Model: F-100
Body: 481
Trans: A
Axle: 09
Max GVW: 5000 (hard to read)
Cert:129 (hard to read)
Max RPM: 4000 (hard to read)
D.S.O.:223463 (hard to read)
Thanks for your help
Old Dec 14, 2012 | 08:12 PM
BarnieTrk's Avatar
BarnieTrk
Color: 115
Model: F-100
Body: 481
Trans: A
Axle: 09
rjbunings, welcome to FTE!
The color code is usually listed between the wheel base and the model. In your case, I'm guessing your wheel base is 115" and your color code was left blank....meaning that it was ordered with a 'special-order color', which is likely since you've got four extra digits on your D.S.O. number, indicating it was a special order truck.
BarnieTrk
Old Dec 14, 2012 | 09:53 PM
SuperSabre's Avatar
SuperSabre
Totally agree with Barnie. 115 = your wheelbase in inches. Color was left blank because it is a Domestic Special Order as evidenced by the six numbers in the DSO space instead of the usual two numbers. Model F100 = half ton truck. Body 481= Standard Cab. It will also give you upholstery color and make up, but unfortunately my magic decoder for that info has died. Trans A = 3 speed manual light duty transmission. Axle 09 = 3.70 gears in a Ford 9 inch non-limited slip axle. 5000 = maximum gross vehicle weight rating in pounds. 129 @ 4000 = your NET maximum horsepower and the number of rpms where it's achieved. 223463 = Domestic Special Order from the regional sales office at Charlotte, NC. The light yellow color was probably called Sunlight Yellow. Hope this helps.
Old Dec 15, 2012 | 09:52 AM
rjbuningsr's Avatar
rjbuningsr
Thank you
BarnieTrk and SuperSabre,
Thank you for your help
Old Dec 20, 2012 | 02:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
481: 4 = Light Beige Crush Vinyl & Light Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
No such color as Sunlight Yellow.
There's no way to determine what the original color was because FoMoCo THREW AWAY all the records for 1961/66 trucks decades ago.
Old Dec 20, 2012 | 12:24 PM
rjbuningsr's Avatar
rjbuningsr
Thank you to NumberDummy
Finding out more about my "Baby" Every day
Thank you again
Old Dec 20, 2012 | 12:31 PM
rjbuningsr's Avatar
rjbuningsr
Original color of '65 F100
The original color....under hood, fire wall, interior looks like a school bus yellow. The truck may have been ordered by a municipality. I notice that some of the South Carolina D.O.T. trucks are painted school bus yellow.... Does any one have any Ideas?
Old Dec 21, 2012 | 04:56 PM
SuperSabre's Avatar
SuperSabre
With due deference to ND's expertise, there is such a color as Sunlight Yellow. It may not have been a standard offering on F100 trucks, but it was offered on '64 and '65 Ford Mustangs, Galaxies, and Falcons, and could have been requested to be put on a truck. The car code for it is "V". I have the '64 and '65 Ford car color charts that show it. It's a pale yellow so probably not what you were talking about. Ford trucks also offered a bright yellow called "Chrome Yellow". But since your color spot is empty and you have the six digit DSO code, it's probable that whoever ordered your truck specified some other color - like school bus yellow. As ND said, no records remain to consult - unless you get lucky like I did and find the Build Sheet still in the seatback springs.
Old Dec 21, 2012 | 08:13 PM
kjvforme's Avatar
kjvforme
How about 8= springtime yellow
Old Dec 22, 2012 | 04:52 AM
NumberDummy
V = Just plain 'ol Yellow not Sunlight listed for 1965 trucks & some 1964/65 Passenger Cars (DL60-1729-A).
V = Emberglow Metallic listed for some 1965/66 Passenger Cars and 1966 trucks. This is the copper color usually seen on Mustang's.
But it doesn't matter what the code is, cuz the OP's truck doesn't have a COLOR code, as it was a Domestic Special Order.
Old Dec 22, 2012 | 09:32 AM
kjvforme's Avatar
kjvforme
Yeah the only true way to figure things out is go back through the North Carolina DMV records and see who the registered owner was. If it was a company maybe they had a specific color for their vehicles.
cbquinn66
Feb 23, 2017 11:27 AM
unibody62
13
Jun 6, 2016 03:04 PM
1963unibody
Nov 11, 2015 06:05 PM
ynkstr
Mar 29, 2008 06:08 AM
66FORDFAMILY
Apr 30, 2007 01:13 AM
