vin decode help
Old Feb 22, 2017 | 09:10 PM
cbquinn66's Avatar
cbquinn66
vin decode help
1966 f100 vin#
F10YK776638
129 JA f100 E 81 G 17
05000 172 4000 65
Old Feb 22, 2017 | 11:09 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Can you check the Color - I think it is likely JM, not JA.
Old Feb 23, 2017 | 12:26 AM
RangerMercMan's Avatar
RangerMercMan
Factory red and black would be cool
Old Feb 23, 2017 | 06:25 AM
cbquinn66's Avatar
cbquinn66
66 f100 color
Hard to tell jm or jh the door tag has been painted at least 3 times.
Old Feb 23, 2017 | 08:41 AM
TA455HO's Avatar
TA455HO
Lead Gopher
This might sound funny but with 1966 it is best to take a nice clear picture of the warranty plate and then you can zoom in on it.
Chad
Old Feb 23, 2017 | 09:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by cbquinn66
1966 F100 VIN# F10YK776638
WB: 129 / COLOR: JA / MODEL: F100 / BODY: E81 / TRANS: G / AXLE: 17 / MAX GVW LBS: 05000 / CERT NET HP: 172 / RPM: 4000 / DSO: 65
F10 = F100 2WD
Y = 352 2V
K = Kansas City MO Assembly Plant.
129" Wheelbase.
JA: J = Rangoon Red / A = Raven Black // JM: J = Rangoon Red / M = Wimbledon White.
F100 2WD .. 5,000 lbs. GVWR
E81: E = Red Crush Vinyl & Red Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
G = MX Cruise-O-Matic.
17 = Ford 9" Rear Axle / 3.25-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
65 = Oklahoma City OK Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Feb 23, 2017 | 10:37 AM
cbquinn66's Avatar
cbquinn66
Thank you sir for the information on the truck.Helps a lot.
Should this truck have 15" or !6" rims on it?
Old Feb 23, 2017 | 10:45 AM
TA455HO's Avatar
TA455HO
Lead Gopher
OK, now you got us all curious. Is your truck the first known truck with a tu-tone paint that doesn't include Wimbledon White or not? You gonna leave us hanging?
Chad
Old Feb 23, 2017 | 10:47 AM
NumberDummy
15" wheels were standard equipment, 16" wheels were optional.
Note: 1966 F100 could have innie or outie wheels/hubcaps.
Innie: So called because the hubcap snaps over tabs located on the inside of the wheels center section.
Outie: So called because the hubcap snaps over tabs located on the outside of the wheels center section.
Old Feb 23, 2017 | 10:48 AM
TA455HO's Avatar
TA455HO
Lead Gopher
My 1966 Salesmens Fact Book says 3 possible sizes of rim diameter for F100 2-Wheel Drive Series.
Standard:
15"
Optional:
16"
17.5"
Old Feb 23, 2017 | 10:53 AM
NumberDummy
Originally Posted by TA455HO
My 1966 Salesmens Fact Book says 3 possible sizes of rim diameter.
Standard:
15"
Optional
16"
17.5"
The 17.5" wheels used on the front fenders with the 45" opening radius.
Old Feb 23, 2017 | 11:27 AM
cbquinn66's Avatar
cbquinn66
tried my cellphone to get better description on the letter.Not an A must be a m.but i would swear it looks like a H.there is a spot on the bed rail were the paint looks like a ivory white.
But everything in the cab is black including dash pad heater vents.door trim is black with a cream or ivory.
BSmart2
Apr 4, 2019 11:47 PM
gangstakr
Dec 13, 2014 12:47 PM
bluecrowbar
Mar 2, 2006 06:43 PM
pilotes
Oct 12, 2004 10:30 PM
newatoldtrucks
Aug 23, 2001 10:16 AM
