Memory Steer
Old Dec 11, 2012 | 10:51 AM
OleGrouch's Avatar
OleGrouch
Memory Steer
Found what could be my steering problem, how to find an alignment specialist who can think, and not just do it the way he was shown. May copy and print this for him to read ( ? ) next time I take it in.
What is memory steer and what can cause it?
Old Dec 11, 2012 | 12:34 PM
neilc88's Avatar
neilc88
Describe your issues. 2 wheel or 4x4?
Old Dec 12, 2012 | 12:02 PM
OleGrouch's Avatar
OleGrouch
When steering and a slight adjustment for a turn or curve is required, the steering will stay as turned and not return to center when wheel is released. Steering seems to be very sensitive and tight, but like all 4X4 it has the front axle drift because it is mounted on leaf springs. I thought maybe a new ball joint that was repleced was still tight, and may be, not sure if it was pulled in by impact wrench or aligned and installed by hand, which I have heard is recomended. It feels as if there was something really too tight or was binding to keep the front wheels from centering up after a turn. Mechanic informed me it was in "spec". I don't really think he is bright enough to even understand algnment principals, so I'm still looking for a qualified shop and an alignment specialist.
Old Feb 9, 2013 | 01:29 PM
ossyossy's Avatar
ossyossy
Memory Steer
My husband is having the same problem. He has been in several times to try to alleviate the problem. He has had ball joints, tie rod ends changed, gone in multiple times and still no luck. The steering does not return to center on its own. Les Schwab states it is possibly the steering box but isn't sure. It's $450 down the drain for a "not sure." Can someone please tell me what is going on? It is only a 4 inch lift. Could that be the problem. Thanks for your feedback.
Michelle and Dan
Old Feb 9, 2013 | 09:50 PM
wrxin's Avatar
wrxin
Ours does the same thing. It'll unwind the steering in a parking lot but not all the way to center. If you're driving down the road and turn the wheel slightly it'll keep going in that direction.
I'm pretty sure it's just the nature of the truck steering technology. I'd be really interested if you find a fix.
I've replaced the steering stabilizer (it was totally shot), all front sway bar hardware and tightened the steering box 1/4 turn. Steering is definitely better but it doesn't return to center like a vehicle with rack and pinion steering.
Old Feb 9, 2013 | 11:12 PM
EXv10's Avatar
EXv10
It's not supposed to and most people put too much blame on alignment. You can align it yourself with no tools and I have been doing it for years. My truck tracks perfectly with my Oklahoma align job.
Vehicles with straight axles only have the caster angle of the axle to bring it back into center and doesn't benefit from the intricacies of the control arm suspension.
Old Feb 10, 2013 | 09:57 AM
Snowseeker's Avatar
Snowseeker
Many things can cause that problem from dry ball joints to sticky gear box to bad bearings in the steering column.
I just replaced the bearings in the steering columns of two of our trucks that had this same problem. The new bearings fixed both trucks.
If your steering feels light and there are no sticking problems with any of the components than it can very well be your alignment. Mostly to return the wheel to center on the alignment side you will be looking at the caster adjustment.
Old Feb 10, 2013 | 10:29 AM
wrxin's Avatar
wrxin
Just to clarify, the only factory adjustable alignment setting is toe. Caster can only be adjusted with the addition of special concentric bushings and some extra $$ for the alignment.
I just had the alignment done and the caster was measured at +3 degrees, which is within Fords massive range of acceptable. I feel that my caster measurement is fine. They also said the front end checked out fine.
Old Feb 10, 2013 | 10:43 AM
EXv10's Avatar
EXv10
Right, the whole front end is basically set when made and rarely needs an adjustment. The toe can affect wander and is easily set by using a string from front to rear, sighting front to rear, or measuring from tire to tire across the front, or all three. I would like to have all the money people blew on needless alignments on these. I could pay cash for a fleet of ex's.
If you have to resort to using/adjusting an eccentric bushing above the top of the b-joint you probably have worn b-joints, wheel bearings, or bent parts. Caster is pre-set and determined by the tilt of the axle like a model A Ford.
regret
36
Jan 13, 2017 06:59 PM
mmccasli
Nov 1, 2008 05:49 PM
kawika
Nov 5, 2007 09:19 PM
JRAYMOND
Nov 2, 2007 08:48 PM
F-150_XL
May 11, 2005 07:17 PM
