Automatic choke setting
Old Jan 4, 2013 | 03:33 PM
  #31
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Just got back with a nice looking one off of an '83, was off of a running/driving truck.I am gonna mount it this weekend.
Old Jan 4, 2013 | 08:39 PM
  #32
Franklin2's Avatar
Franklin2
I doesn't have any wires coming out of it does it? You have to be careful with the 300 carbs, they went to computer control sometime around then.
I think if you buy carbs from a junkyard, and expect to bolt them on and go, you might be disappointed. They sit around with old gas in them, and get all gummed up, and they were probably in need of a rebuild when they were being used before they went to the junkyard.
If the truck half-way runs when you bolt the carb on, I would put a kit in it.
Old Jan 4, 2013 | 08:42 PM
  #33
Gary Lewis's Avatar
Gary Lewis
I posted something like Dave's post - I thought. Wonder where it went? Anyway, right on about the feedback carbs. Just make sure it doesn't have those wires. But, if it came off of a running truck it should be at least good enough to bolt on and try.
Old Jan 4, 2013 | 08:57 PM
  #34
78 & 87 Super Cab
No wires coming out of it. The one I am using now came from the same yard, and has run great with it. This one I picked up today has E3TE-ASA on the ID tag,was driven to where it was parked
2 months ago
Old Jan 4, 2013 | 09:00 PM
  #35
Gary Lewis's Avatar
Gary Lewis
That should be the right carb.
Old Jan 5, 2013 | 05:35 PM
  #36
78 & 87 Super Cab
Here it is, after spraying the dust off it:
Check out how rich the choke is, on this one I don't see any index marks on it, how in the heck am I supposed to set it? It's already on the high step of fast idle cam, I may move it counter clockwise and feel the tension on it
Old Jan 5, 2013 | 05:38 PM
  #37
Gary Lewis's Avatar
Gary Lewis
I think that one was riveted at the factory setting, so they didn't see a need for marks. Notice that the two screws we can see in the picture are different from each other? I think the PO drilled the rivets and used whatever screws were handy.
Use a light colored, like silver, Sharpie to put some marks on it before you start playing. That way you can get back.
Old Jan 5, 2013 | 05:40 PM
  #38
Franklin2's Avatar
Franklin2
Why would you want to adjust it? You said the "truck ran when they took it to the yard". It's supposed to be a bolt on and go correct? Sorry for the sarcasm, I do not like junkyard carbs unless they are rebuilt.
Old Jan 5, 2013 | 05:48 PM
  #39
78 & 87 Super Cab
I actually meant IF I had to adjust the choke in the future, did not mean I was going to do so now.
I have used salvage yard carbs on ofher vehicles I have owned in the past, always had good success with them.
Old Jan 5, 2013 | 05:50 PM
  #40
78 & 87 Super Cab
Yeah, I just looked at the pic, and saw the screws
J.McConnell
Jan 22, 2016 02:37 PM
bryan_johnson
May 12, 2006 11:54 PM
1981 f150
17
Feb 9, 2005 10:48 AM
69crewcab
Feb 15, 2003 07:05 PM
tamarackstyle
1978 - 1996 Big Bronco
Dec 2, 2001 03:26 PM
