Heater Control Lights
Old Dec 10, 2012 | 03:02 PM
RadioControlGuy85's Avatar
RadioControlGuy85
could anyone tell me how do you change the lights in the heater control?
truck is a 85 f150 300 inline6
thanks
Old Dec 10, 2012 | 04:49 PM
CountryBumkin's Avatar
CountryBumkin
Just slide the radio out (don't need to disconnect anything) and then you can reach through the opening to the heater controls below. The bulb is the same type used in the front side marker lights (a 194 I believe). The light bulb plug/harness takes a 1/3 turn to remove it (like the socket/bulb in the side marker light)
Old Dec 10, 2012 | 04:52 PM
81ChopTop's Avatar
81ChopTop
Here's a pic of the back, bottom of the control unit. The light is in the middle. With the wiring attached, it can be a pain. You can unhook it, then it will turn as stated before. This is a newer unit, but the light is the same thing.
Old Dec 11, 2012 | 01:06 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You can also reach the bulb from the bottom if you remove the ash tray...
Niwrek
Jan 26, 2016 07:35 PM
J ballan
22
Dec 3, 2012 05:59 PM
94XLTFLAREI6
Oct 6, 2012 08:17 PM
ralf12
Dec 11, 2009 11:33 PM
77snb
Nov 2, 2001 10:23 AM
