No heater control lights
Old Dec 7, 2009 | 07:58 AM
ralf12's Avatar
ralf12
I have a new to me 1997 Expedition. The lights for the heater controls don't work, but all the other dash lights do. It is probably the bulbs in the control.
What size bulbs are they, and how do I get the cotroller out to replace them?
Thanks,
Pat
Old Dec 7, 2009 | 12:11 PM
PassengerDan's Avatar
PassengerDan
I couldn't believe that all my bulbs had failed in my control when I took it apart, but they were.
Even the blower switch back-light was bad.
The bulbs aren't replaceable in a conventional plug and play sense.
With my Navigator, the bulbs were soldered in. I un-soldered them and installed replacement bulbs I bought from an electronics supply place.
It was a tricky job, how good are your miniature soldering skills?
The get the control out, you pop the radio trim off and then remove 4 screws that hold the control in. The bottom 2 screws fight a little and it's a tight fit but you can get them out.
Old Dec 7, 2009 | 12:14 PM
ralf12's Avatar
ralf12
My soldering skills are passable anyway. What kin/size/etc bulb did you use? If you ordered it online, can you provide the link to it?
Thanks
The bulbs aren't replaceable in a conventional sense.
Old Dec 7, 2009 | 12:18 PM
PassengerDan
Thanks
One of these should do the trick:
14V 40MA T-1 (3MM) LAMP | AllElectronics.com
14V 100MA GRAIN-O-WHEAT 4.2MM INCANDESCENT | AllElectronics.com
14V T-1 3/4 5MM DIAMETER BI-PIN LAMP | AllElectronics.com
Old Dec 7, 2009 | 12:25 PM
ralf12's Avatar
ralf12
Thanks, I will give them a try. How many bulbs are there?
Old Dec 7, 2009 | 12:55 PM
PassengerDan
If I remember correctly, there are 7 bulbs including the blower switch.
Old Dec 7, 2009 | 04:07 PM
alloro's Avatar
alloro
Anyone know if LEDs can be used instead of incandescent bulbs and the LED specifications to do so?
Old Dec 7, 2009 | 06:19 PM
madsonp's Avatar
madsonp
I don't see any reason you couldn't use LED's as long as you get ones about the same size, you'd just need to get some rated for 12 volts and figure out the + and - side of the connection, which would be easy with a meter.
Old Dec 7, 2009 | 06:31 PM
alloro's Avatar
alloro
I have this write-up for using LEDs on both the headlight and 4WD selector switches.
http://www.cardomain.com/ride/296394/12
Old Dec 7, 2009 | 08:02 PM
PassengerDan
Yes. I originally used LEDs but they're too directional and don't light up well enough.
The write up is for a different style bulb. The bulbs on the control I had apart were soldered right onto the circuit board.
Old Dec 7, 2009 | 08:07 PM
madsonp's Avatar
madsonp
You should be able to use these type LED's which don't require an external resister like is shown in your link. 12V BLUE DIFFUSED LED, 5MM (T1 3/4) | AllElectronics.com
Old Dec 7, 2009 | 08:08 PM
madsonp's Avatar
madsonp
Did you try the high output LED's ?
Old Dec 11, 2009 | 11:33 PM
PassengerDan
I used what I had at the time.
Update to the OP: I would pull the control head out before ordering parts. I did some Internet digging and have seen a few control heads that had serviceable or replaceable bulbs.
I can only speak with great certainty that my vehicle in my garage has non-serviceable lights.
