Heater control lights?
Old Dec 2, 2012 | 07:23 PM
J ballan's Avatar
J ballan
Hello fellow FTEers, should my 79 f150 have illuminated heater controls? Sure would be nice. I took it apart today and couldn't find any bulbs or wires hanging behind the controls. This leads me to believe that they didn't have this option? Also how about the PRND21? This would also be nice to have. Any information on either of these would be greatly appreciated. Thanks
Old Dec 2, 2012 | 07:33 PM
fmc400's Avatar
fmc400
MSEE
Both items you mention are supposed to light up. The heater controls use a small pigtail that is press-fit into the back of the panel. The gear selector light is part of the turn signal switch.
Old Dec 2, 2012 | 07:39 PM
J ballan's Avatar
J ballan
Oh good, ok first question what color should the wires be for the heater control light? It wouldn't surprise me if they were cut off back there somewhere. Lol. Second question, can I change the bulb in the turn signal switch or do I need a new switch? Thanks for the help.
Old Dec 2, 2012 | 07:46 PM
ranger429's Avatar
ranger429
The gear selector bulb is behind the selector panel. You have to remove the plastic collar at the dash to get to the bulb socket.
The heater selector bulb is a 194 and the color of the wires is blue and black. The OE wiring is tight to the side if the control selector. The bulb socket is in the middle of the back of the selector.
See above reply, the selector bulb is an 1816 IIRC.
Old Dec 2, 2012 | 07:53 PM
J ballan's Avatar
J ballan
Ok, so for the heater control I'm looking for one solid blue wire and one solid black wire? Also is the bulb socket molded into the plastic? Thanks for the help.
Old Dec 2, 2012 | 07:55 PM
ranger429's Avatar
ranger429
No it is a removable socket. You really can't miss it unless it is not there then there should be a hole in the controller.
Old Dec 2, 2012 | 08:00 PM
J ballan's Avatar
J ballan
Its definitely not connected to the heater controller and I don't remember seeing a hole for the socket but then I didn't know what I was looking for, lol. You wouldn't have a picture of this? Sorry for being a PITA.
Old Dec 2, 2012 | 08:12 PM
ranger429's Avatar
ranger429
No picture, if the socket is gone there should be a spot for it.
Old Dec 2, 2012 | 08:16 PM
J ballan's Avatar
J ballan
Thanks for the help guys. Will dig a little further into this when I get time. Let there be light.
Old Dec 2, 2012 | 08:53 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here are a couple of pictures of the heat control panel and pig tail.
I don't have any of the gear selector.
The first picture is the light pigtail. The second you can see the hole that the light fits in.
Old Dec 2, 2012 | 09:06 PM
fmc400's Avatar
fmc400
MSEE
Thank you for the correction; I was thinking of something else. Sometimes it's hard to keep everything straight.
Old Dec 2, 2012 | 10:14 PM
J ballan's Avatar
J ballan
So do I have to remove the wheel to get at the bulb? Or can I just remove this collar and get access to it that way? Thanks again.
Old Dec 2, 2012 | 10:17 PM
J ballan's Avatar
J ballan
Thanks mike now I know exactly what I'm looking for. I have a feeling that wiring pigtail is going to be cut off and missing.
Old Dec 2, 2012 | 11:23 PM
fmc400's Avatar
fmc400
MSEE
Just the plastic collar. You do not have to remove the steering wheel. When I originally responded, I was thinking of an earlier-model turn signal switch and I was incorrect. ranger429 was able to catch my mistake.
Old Dec 3, 2012 | 09:53 AM
J ballan's Avatar
J ballan
Ok I found the wiring pigtail for the heater control light and picked up a bulb. Now for the column light. Thanks for the help.
