Coil problem
Old Dec 9, 2012 | 10:16 AM
panteramatt's Avatar
panteramatt
Coil problem
My wifes 3V mountaineer has had a bad miss for a long time now. It seems fine until around 40-60 mph where it bucks and misses bad. I replaced all the plugs and it went away for a while but its back again. So far Ive replaced 3 of the coils with the accel coils but its just a shot in the dark really. Can you guys tell me an easy way to check the coils or cylinder to see which one is truly the culprit?
Old Dec 9, 2012 | 03:10 PM
aquanaut20's Avatar
aquanaut20
If it bucks and misses enough times it will set a MIL... or you could connect an OBDII scanner and check for PENDIN codes.... Philip
Old Dec 9, 2012 | 03:12 PM
panteramatt
It bucks all th etime between 40-60 but no cel.
Old Dec 9, 2012 | 03:16 PM
aquanaut20's Avatar
aquanaut20
I doubt you have a coil issue, does the CEL illuminate when you first turn ignition on (no start)....... Philip
Old Dec 9, 2012 | 03:20 PM
panteramatt
I believe it comes on then goes off like its supposed to.
Old Dec 10, 2012 | 08:43 AM
KhanTyranitar's Avatar
KhanTyranitar
Bucking under load is more often an issue with a sensor such as the MAF. Clean it with MAF sensor cleaner and see if it doesn't improve. Do yourself a favor and replace the POS Accel coils with Motorcraft.
Old Dec 10, 2012 | 01:39 PM
panteramatt
Really? The accel coils are junk? That sucks. Spent like $120 on 3 of them so far.
Old Dec 10, 2012 | 02:21 PM
aquanaut20's Avatar
aquanaut20
That is why it is best to fulfill the basic diagnostics first.. Philip
Old Dec 10, 2012 | 03:00 PM
panteramatt
Sorry but what do you mean by that? I dont have a cel so Im not sure on the problem.
Old Dec 10, 2012 | 05:16 PM
aquanaut20's Avatar
aquanaut20
Miss-fire/bogging under load can manifest under many circumstances...
I suggest connecting a LIVE DATA SCANNER.
Check for pending codes,
then record the values for MAF, O2, LTFT, ECT.
Verify correct fuel pressure,
...Philip
gabriell12123
Sep 5, 2018 09:27 AM
scout63
May 12, 2010 10:39 AM
JASON11WS6
1997 - 2003 F150
Aug 9, 2007 10:42 PM
joshperrymon
Modular V8 (4.6L, 5.4L)
Dec 22, 2004 05:40 PM
mebe2k
1983 - 2012 Ranger & B-Series
Feb 19, 2004 11:27 PM
