Steering Box replacement
Old Dec 6, 2012 | 08:23 PM
LITTLE BLACK TRUCK's Avatar
LITTLE BLACK TRUCK
Ill be replaceing my steering box soon and was thinkin about getting a rebuilt one from NAPA. My truck currently has manual steering and I was gonna convert it to power steering, as far as I know the two boxs mount up the same. Any other place I should consider getting a steering box from? My truck is a 78 F100 2wd and has a 300 inline 6. Thanks in advance.
Old Dec 6, 2012 | 08:30 PM
Jimmyrig's Avatar
Jimmyrig
I would go to the junk yard and pull the entire PS system off another truck or a jeep cherokee.
Old Dec 6, 2012 | 08:33 PM
LITTLE BLACK TRUCK
I thought about doing that. Elaborate on the jeep cherokee? Will the box off a jeep cherokee bolt up?
Old Dec 6, 2012 | 08:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If I recall correctly, the steering column is shorter.
Redhead Steering gear in Seattle, WA is the best place to get a rebuilt steering box.
Old Dec 6, 2012 | 08:40 PM
LITTLE BLACK TRUCK
Ill check em out, thanks Mike.
Old Dec 6, 2012 | 08:43 PM
Jimmyrig's Avatar
Jimmyrig
you would need to look at the box. Might not be too far off, but the PS pump, pressure, and return lines are gonna be your biggest challenge and those should match up from the cherokee.
Old Dec 6, 2012 | 08:50 PM
fmc400's Avatar
fmc400
MSEE
I bought a rebuilt steering box for my '79 from Napa several years ago. It works fine, but I didn't know about Redhead at the time. Had I known about them, I would have gone that route. "Rebuilt" steering boxes from most parts stores are just painted and sealed; nothing internally is actually rebuilt. They can have a lot of slop in them still. I think I just got lucky.
Old Dec 6, 2012 | 10:39 PM
Behemoth's Avatar
Behemoth
I just got my steering box rebuilt by Red Head Steering, and I have to say, those guys do NOT mess around! I mailed them my box on a Thursday night, they had it Friday morning, had it built by Friday night, and i had it back on Monday afternoon.
They not only rebuild the box, they improve it.......the sector shaft on these boxes is the weak link because they rub against the casing, and can form stress cracks. So, the guys at Red Head bore the box out, and install needle bearings around the sector shaft so that it will turn smoothly without rubbing on anything.
Granted, they're not dirt cheap, but they do it right. The rebuilds by A1 Cardone have new seals, and not much else from what I've been told.
Before I went to Red Head, I searched the internet for reviews on their work, and it seems that most everyone swears by them. Might be the best bang for the buck.
Old Dec 6, 2012 | 11:20 PM
LITTLE BLACK TRUCK
If its not too bold of a question how much did it cost to have your box rebuilt by red head?
Old Dec 6, 2012 | 11:31 PM
tbear853's Avatar
tbear853
Oh man .... there was just a group buy here on FTE for Red Head Steering boxes Dec 3rd - 5th. Last count, 43 got in on it, they even let one guy participate and enjoy the $60 savings early today the 6th. It was started by a member with an Excersion but was open to any with a Ford.
https://www.ford-trucks.com/forums/1...ox-buy-12.html
In my case, '77 F-150 4X4 w/ps was $326 plus refundable core charge $150 and $35 shipping to me = $510 minus $60 group buy discount = $450 on my card and then I'll mail my orig box back for a core refund using a large "if it fits it ships" USPS box with insurance ($15+5=$20) (up to $470 cost now) for a refund of $150 on my card means total costs to me $320.
Old Dec 6, 2012 | 11:39 PM
LITTLE BLACK TRUCK
I was expecting to spend around $400, if I do go with red head ill have them rebuild the manual steering box. From the way it looks they are well within my budget. Thanks
Old Dec 6, 2012 | 11:45 PM
tbear853's Avatar
tbear853
'78 F-100 2WD Power Steering box .... look at post #48 about page 8 I think ... core charges varied with unit desired. As I recall, this was a partial listing .... any not listed just call them. They have a large inventory of already built units, I called Monday the 3rd and my new box arrived Wed the 5th before 3pm and I live in Va. I'm sure they'ld have the PS box you want and still take your man box as a core if you like thougfh core allowance migfht be adjusted somehow?
Originally Posted by kornfanjoe
Email from redhead.
VERY USEFUL INFO!
On this, it depends on what the application is.
From a high of $446 exchange for the 07 1/2 to 2010 SuperDutys.
$396 exchange for the 05 to 07 1/2 SuperDutys.
$346 exchange for the 2000-2004 SuperDutys.
$326 exchange for the 77 1/2-79 F-250 and 350 4x4s.
Also, $326 exchange for 76-79 F-150 4x4 and 78-79 Broncos.
$286 exchange for the late 97-99 F-250s and F-350s with 32 splined output shafts---not with 36 spline.
$256 exchange for the 80-97 1/2 F-150 through F-350 2wd, 4wd, vans, rangers, etc.
$256 exchange for 1970-79 F-150, F-250, and F-350 2wd.
$456 exchange for the 1965-69 2wd with BENDIX power steering gear.
$326 exchange 68-75 1/2ton 4x4 with manual steering.
Same for 68-75 Bronco with manual steering.
$236 exchange 65-79 F-100 through F-350 2wd with manual.
$396 exchange 1968-77 1/2 F-250 and 350 4x4 with and without power steering. Same steering gear, different ratio.
$356 exchange 73-77 1/2 F-250 and 350 with BENDIX control valve.
$346 exchange Ram cylinder for same vehicle.
$356 exchange 1975 F-100 4x4 with Garrison Control Valve.
$356 exchange 1968-72 F-250 and 350 with Garrison valve.
$246 exchange 68-74 Econoline Van with or without power steering. Same steering gear, different ratio.
$246 exchange 75-82 Econolines with Saginaw steering gears.
Old Dec 6, 2012 | 11:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I had my steering box rebuilt by Red Head a little over a year ago, the cost was $226.00 plus the $50.00 it cost me to ship it to them.
This was a '73 2WD w/ power steering
F250racer
Montana Chapter
Apr 30, 2014 08:17 AM
CanadianSmokie
Oct 25, 2007 11:28 AM
