Ok, I've had around 5 different bump and dent side 4x4 trucks over the years. All of them have had front drive shaft issues, ALL of em!
I've never had a rear drive shaft issue on anything before.
Last night I was under my 77 F250 changing a U-joint on the short shaft between the trans and the transfer case.
I grab the front drive shaft and rotate/wobble checking the U-joint at the transfer case. Those damn splined slip yokes, it was just floppy as hell! Uhhg, it's junk! (like the front shafts on 3 other old trucks I own right now)
So what is it about these front shafts? Why do they go bad and the rear shafts dont?
Is it the female splined yoke portion that wears or is it the splined stub shaft itself? Both?
You get what you pay for un U joints. Spicer are expensive but last a lot longer. If you buy a new slip yoke and keep it greased it will last a long, long time. Problem probably was the persons before you didn't keep up on greasing things and once it's worn thats it, no amount of grease will fix a worn slip yoke.
So, I wonder if I put a new slip yoke on... I might be able to find a new one. But I don't know if the splined stub and the slip yoke wear evenly or? If just a yoke would fix it I'd do that in a heartbeat. But I'm afraid I'll have to have a machine/welding shop cut the old stub off and weld a new one on with a new yoke, then ballance it.
I was told several years ago by the owner of a reputable drive shaft shop that what you're describing is a rather common occurrence. He said that it's partly due to the fact that the front shaft just sort of floats there without being under torque. Sorry, I can't remember the rest of the explanation.
I've got the exact same problem on my truck. It worried me so much that I picked up a spare just in case. My friend said that his did it too and would chatter driving down the road. I figured it's just one of those parts that doesn't last.
i've got the same problem. the trip down the street to our mud hole is about 1/2 a mile so ive never even thought to replace it. mine has been that way for about 5 years. still works. one day i'll get one built. Driveline services here sacramento said they'd build me one for $200. still havent needed it yet. i'll prolly be up to my doors when its had enough.
