Rear Axle speed sensor
Old Dec 2, 2012 | 08:35 PM
ROBZ95XJ's Avatar
ROBZ95XJ
94 F250 7.3 fact turbo 2wd auto
what is the purpose of the speed sensor on the rear axle besides abs? anyway to baybass it with an auto? i only ask cause i can get a AAM with gov lock locker and disc for the price of rebuilding this 10.25
Old Dec 3, 2012 | 04:59 PM
airdale94's Avatar
airdale94
It should also send a signal to transmission PCM, but not certain. You might be able to get some kind of aftermarket "box" that would run off the driveshaft. Probably expensive though.
Old Dec 3, 2012 | 05:04 PM
tecgod13's Avatar
tecgod13
I dont remember when it changed over, but if you truck has an electronic speedometer, it gets the signal from the speed sensor as well.
Old Dec 3, 2012 | 05:10 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
yeah you need that sensor. It is a must for the trans to work properly and it also controls you speedo.
gccch
2004 - 2008 F150
Apr 2, 2018 06:37 AM
zavierbr
Mar 31, 2009 10:13 AM
maverick1701
Oct 6, 2008 09:33 PM
ghunt
Apr 5, 2008 12:49 AM
schocker
Jul 27, 2007 02:47 PM
