Speed sensor
Old Mar 31, 2009 | 09:42 AM
zavierbr's Avatar
zavierbr
Arrow Speed sensor
Hey guys,
I was wondering where on the 2000 Excursion would the "speed sensor " be located? How would you no if the speed sensor is going bad? will it be an expensive fix? Thank you.
Old Mar 31, 2009 | 10:13 AM
pbr man's Avatar
pbr man
The VSS (or ABS sensor if you go to Napa) is located on the top of the rear axle. Symptoms of failure is speedometer working erratically, ABS light coming on, or having to turn the ignition off and restart to get the speedometer to work.
It takes about 10 minutes to change it out and mine was about 15 bucks at Napa.
