Sponsored by: Real Truck
Tire question
Old Dec 2, 2012 | 07:40 AM
michaelc03's Avatar
michaelc03
Tire question
Hey i have a 2002 f250 ext cab 4x4 w 5.4 motor in it can you use goodyear wrangler authority tires that they sell at walmart with load range c on them, will that be good or not?
Old Dec 2, 2012 | 07:52 AM
Tom's Avatar
Tom
Hi Michael, welcome to FTE!
You bumped a 5 year old thread, I'm going to split your thread off onto a post of its own.
Old Dec 2, 2012 | 07:56 AM
Tom's Avatar
Tom
And the answer is NO. There's a high likelihood that Wal-Mart wouldn't even install these tires on your truck because they are not rated for the max weight of your truck. I can't find specs on this particular tire, but from what I can tell most LR C tires in this size have a maximum load of 2,470 per tire at 50 PSI.
Your truck requires load range D tires at a bare minimum, and preferably load range E.
Old Dec 2, 2012 | 08:13 AM
senix's Avatar
senix
Do not use a load range C tire for this truck. You will likely exceed the capacity the minute you put them on the truck..if they will even sell them to you.
E-rated are what you need. Your rear end probably comes in at around 2800 unloaded.
Old Dec 2, 2012 | 08:45 AM
Quad Racer's Avatar
Quad Racer
Yeah, what they said. No way I'd put c rated tires on. Bite the bullet, tires for these trucks are not cheap.
RobertJohn
Apr 24, 2007 12:13 PM
foxracer800
Mar 12, 2006 09:02 AM
JMACC
May 25, 2005 09:46 AM
ExpySport
Nov 7, 2004 07:31 AM
F15099
Apr 27, 2004 10:21 PM
