Mare's (dually) mod list!
Old Dec 1, 2012 | 10:46 PM
oldbird1965's Avatar
oldbird1965
This stuff has been swirling around in my head and to put it into a list is shocking, a real reality check. I'm not going to get all this done, all I can say is OMG, what have I gotten myself into?? I'm sure I've forgotten a few things. I want to know who's bright idea was it to get a dually cc? LOL
1. John Woods trans-DONE
2. GP relay switch-DONE
3. Brakes-DONE
4. Front end alignment to be done Tuesday. DONE
5. Take off fuel bowl and install E fuel.
6. Send injectors to Jim for stage II's.
7. Remove DP & stock exhaust, install diamond eye 4" turbo back exhaust.
8. Send in HPOP to Joey for a T500.
9. Mod the fuel tank filler necks.
10. Replace multifuntion switch (no emergency flashers working)
11. Replace GP's
12. Replace UVCH's
13. Installl s366 turbo and IC mount kit.
14. Install IC
15. Install 6.0 trans cooler
16. Swap aluminum radiator out of the mule into the mare.
17. Swap starters
18. Swap alternators DONE
19. Swap batteries DONE
20. Swap GPR's DONE
21. Install new U joints & carrier bearing.
22. Trans filter
23. Coolant filter
24. 6637
25. CCV mod
26. New water pump
27. switch over water injection, don't connect it up LOL
28. switch over my aux fuel tank
29. switch over my 5th wheel hitch & tailgate.
30. switch over dual tensioner mod DONE
31. switch over the new coolant overflow tank
32. switch over the FS2500 oil bypass
33. switch over the my diy oil cooler
34. switch chips, Tony's into the mule and Beans into the mare. DONE
35. put new raditor hoses in
36. Install 5 gauges, fuel pressure, oil pressure, EGT, coolant temp, boost. Scan guage already switched over.
37. Switch Map sensors DONE
38. Switch mule's HVHF Swamps IDM over from mule to the mare DONE
39. Change out passenger seat belt, its torn.
40. Get a new toolbox.
Old Dec 2, 2012 | 12:55 AM
95_Dually's Avatar
95_Dually
That's some list Glenn. Good luck.
Old Dec 2, 2012 | 01:49 AM
stainlessstroker95's Avatar
stainlessstroker95
Thats one heck of a list Glenn. I hope every thing goes together smooth. Looking forward to watch it being built.
Old Dec 2, 2012 | 06:17 AM
Midwest Dually's Avatar
Midwest Dually
I will take the blame for the CC Dually push! LOL
Old Dec 2, 2012 | 06:54 AM
427 fordman's Avatar
427 fordman
Now that is a good list Glenn! Good luck with it, and I'm looking forward to updates. It is scary, when seen wrote down, all the things a guy wants to do.
Old Dec 2, 2012 | 07:06 AM
DIYMechanic's Avatar
DIYMechanic
Subscribing to the thread for the mare! Good luck Glenn, that's a list for sure, but slow and stead will get it done.
Old Dec 2, 2012 | 07:47 AM
WALJON's Avatar
WALJON
Wow that is some list you must be retired to have time to do all that lol.
Old Dec 2, 2012 | 08:22 AM
fordman67's Avatar
fordman67
Glenn...you are my hero! Haha I was wondering when you were going to start a build thread.get on it...i got a couple weeks vaca....i could fly out and give a hand hehe
Old Dec 2, 2012 | 09:26 AM
oldbird1965
Thanks guys, now that I've slept on it, the 'swaps' and 'switch's' will be easy. Like the alternator for example, I'm not leaving a high output it in the mule. The main thing will be e fuel, turbo, IC, trans cooler, injectors, exhaust.
Old Dec 2, 2012 | 12:18 PM
oldbird1965
Forgot, put swamps HVHF IDM into the mare and the 140v IDM that I had in the mule for years back in. Another thing that I've had done already is the bed rino (rhino sp?)coated, turned out really nice!
Old Dec 2, 2012 | 12:35 PM
fordpride's Avatar
fordpride
Glenn are you keeping the mule ?
Old Dec 2, 2012 | 01:08 PM
95_Dually's Avatar
95_Dually
Go Glenn Go!!!!!
Old Dec 2, 2012 | 01:48 PM
oldbird1965
I really haven't decided yet, make me an offer! LOL
Old Dec 2, 2012 | 02:28 PM
richdawg's Avatar
richdawg
This is going to be a very interesting thread, sure wish I could have came down for the winter, I would have loved to have spent some dime helping out. Ya never know I might have just learned something too How is your suspension on the mare? Mine would be a little better if I had air bags as it just don't set quite level enough for me. I handles good though, my pin weight is a little high at close to 3k.
Old Dec 2, 2012 | 02:34 PM
Awitte58's Avatar
Awitte58
So Subscribing! What a list indeed! GO GLENN GO!
