Headlight installation
Old Nov 30, 2012 | 09:37 PM
lartross's Avatar
lartross
It always amazes me how hard many of the things y'all commonly do and just say...I did that a half hour ago...So I installed 2002 2004 after market headlights. What a Beech! Tried Springer Pop's method...no cookie...tried the book method...it worked, but, well...the book said take the two upper retainers off and the one lower...three hours later, I got the first one off. After learning the trick, 15 minutes later, I got the other side off. Most of the jobs on this truck have been like that. Like to kill myself the first go around...gets a little easier the next time. Well, just had to beech a little...
Old Nov 30, 2012 | 09:42 PM
BigAlsPSD's Avatar
BigAlsPSD
Sorry they gave you trouble, Larry.
I did this a few weeks ago, and didn't see the need to do any type of write-up as they were basically remove and replace in the same locations. Trying to remember back, I don't recall running into any issues either...
Anyway, got pics? Are you using regular bulbs or did you go with upgraded harnesses and 80/100 watt bulbs.
Old Nov 30, 2012 | 09:48 PM
lartross's Avatar
lartross
Just regular bulbs...you're probably a lot quicker than I, Al...I had to figure out how to pull the top clips off...took forever...and wrestle with several tools to get that bottom thingy-jiggy out. Once I got a routine...it was much easier. Didn't take pics...guess I'm kinda' backward that way, also.
Old Nov 30, 2012 | 10:03 PM
BigAlsPSD's Avatar
BigAlsPSD
The only clips I remember were the locks for the adjusters gear assembly, but I left the originals on and just ran the adjusters all the way out, then reinstalling them to run into the new assemblies.
I guess if you were installing new adjusters too, then unclipping the locks will allow them to pop out.
Oh well, glad you got it, should be noticeable light output.
Old Nov 30, 2012 | 10:21 PM
pin8246's Avatar
pin8246
I pulled the top 2 adjusters and just backed the bottom one completely out when I did mine.
Old Nov 30, 2012 | 10:24 PM
lartross's Avatar
lartross
Yeah, I tried that and ran it the wrong way and popped the ball out of the headlight! So, I went the other route, which, once I figured out how to do it [grab the locking tab with a bent sharpie and pull to the side and up] was easier to me. There wasn't anything too easy about getting the bottom thing out, but it got out.
Old Dec 1, 2012 | 01:24 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
A job done hard is still a job done!
Those pretty clear lenses shore could use some output!
Old Dec 1, 2012 | 07:50 AM
woodnthings's Avatar
woodnthings
The clips can be a little tough. I converted to '05's and posted it HERE
fletchb
1983 - 2012 Ranger & B-Series
Sep 5, 2018 02:24 PM
Docdor
May 7, 2008 12:42 PM
bowhunt24
2004 - 2008 F150
Jul 31, 2007 10:31 PM
timcommon
Oct 29, 2006 04:56 PM
05f250fx4
Aug 8, 2005 11:07 AM
