Has anyone else ever had to deal with a fuel filter cap that looks like this one. It takes a 1 inch wrench to fit it, but every tool I have tried using has just slipped off and started gouging the head. I have watch a few videos and read a few threads on replacing the fuel filter, but have not seen a cap like this one yet. Please help.
Thanks everyone, I will try the oil filter wrench idea. I have tried using lock pliers but they just started ripping the plastic off. I just hope there is enough side wall to the lid to get a grip.
Did your new filter come with a replacement lid? If it did a small hammer and a chisel should be able to get enought bite to spin it off if all else fails.
Yah, got it off. Oh my gosh was that thing dirty. Had to use a ratchet with a crows foot and almost hold it down with my chest while I turned it very slowly. Should I be worried if it looks like there is sand at the bottom of the filter bowl? going to clean it out, but everything else looks good. the old filter didn't even have a screen and looks half the size of the one I got to replace it.
I have that same cap, didn't realize it was non-OEM. I used a 6 point socket on that thing and it worked pretty well. Will be changing to the OEM cap now that I know this is aftermarket.
