removing headlights
Old Aug 4, 2005 | 10:11 PM
05f250fx4's Avatar
05f250fx4
removing headlights
anyone know how to do this? i've only gotten the inner mount off, i cant figure out how to do the rest. i've got a pair of 350z HID bulbs and ballast. im trying to retrofit it somehow to my clear lensed headlights. i cant see much with stock. if anyone has any tips or has already done this retor fit, please help!
Old Aug 5, 2005 | 01:35 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Just to clear up some confusion, is it just the bulb and harness you're replacing?
Old Aug 7, 2005 | 12:27 AM
05f250fx4's Avatar
05f250fx4
right now, i have the 99-01 housing which is translucent/fuzzy/hazy. i want to replace it with the 02-04 housing and at the same time retrofit the hids into it.
Old Aug 7, 2005 | 02:20 PM
Toreador_Diesel
Oh ok, I did this a few weeks ago, I even have some installation pics in my gallery. Before you do this, you should take some pics in your garage or atleast, mark where the old headlights were aimed. Just a disclaimer.....
The only hard part about doing the swap is the headlight itself. (The left side is relatively easy, the right side isn't so easy, it just requires a little more effort. )The headlight is held in place by 2 metal clips right behind the light. You'll need a pair of pliars that can get a good grip on those clips. From there, all you have to do is pull up and that's it; but be careful, if those break it could make things a smidge harder. (plus they're expensive at the dealer) Once you manage to get those clips off, you'll need to turn the adjuster screw (located at 2 o'clock) to the right, NOT the left. (you'll need a socket for this) A word of caution, make sure you use snug fitting socket otherwise you'll round off the head and make adjusting difficult later on. (take it from someone who knows ) Once you've got that going, the headlight should make it's way out. Once it comes out enough, it's in your best interest to unplug the harness from the bulb. Once you have the head light out, you can easily replace the turnsignal assembly no problem. The assembly is held together by two philips head screws directly below the signal itself. Once you get the screws out, all you have to do is lightly pull and it should all come off. From there, it's a bulb swap, then vice-versa.
As for the re-installation of the headlights, it can be quite tricky. If you ordered from www.carlightswholesale.com like I did, you probably got a whole new adjuster screw. It's difficult to put in, so unless you really want to, I wouldn't bother with it. The flat side of screw that goes into the adjuster ( seen and circled here ) has to face up and be as level as possible otherwise it won't work. But before you do this, you should change out your bulbs and plug the harness back in. Once you do that, you have to line the screw up with the adjuster and push it in as far possible. When it stops, get your socket and start turning to the left and the light should start pulling itself in. You'll probably have to push on it a little, but not too much. Once you get things lined up again, put the metal clips back in and you're done! All you have to do now is adjust the your headlights and you're good to go!
I've done the best I can to explain this and I hope I haven't left anything out. Best of luck to ya'!
Old Aug 8, 2005 | 11:07 AM
05f250fx4's Avatar
05f250fx4
thanks man, im going to get crackin at this asap. still waiting for the clear headlgihts to come in. i think my headlights may be a little different than yours. there are two clips, but the ones closer to the grill can be turned so that the headlight slides out. while the outermost clip is more difficult. it has a metal piece that i still cant figure out how to get it out. i did accidentally break off a piece of the metal though, i dont think there is any serious damage. its still usable
atomicjoe23
28
Jul 12, 2015 06:52 PM
mike2112
Apr 29, 2006 11:03 AM
king richard
Bronco II
Aug 18, 2005 08:19 PM
FedExguy2004
Electrical Systems/Wiring
Oct 24, 2004 10:16 PM
