Sponsored by: Real Truck
custom kill switch?
Old Nov 30, 2012 | 11:57 AM
dvourthis's Avatar
dvourthis
custom kill switch?
So I did some research on the forums and did not find what I was looking for. I want to wire up a kill switch to one of the existing Aux switches. I have a diesel and I was wanting to wire it up for the ignition system. I am fairly competent with mechanics but not with electronics, please any info would help!
Old Nov 30, 2012 | 12:04 PM
TexasRebel's Avatar
TexasRebel
Diesels don't have an electronic ignition system. Heat from compression ignites the Air-Fuel mixture.
Old Nov 30, 2012 | 12:25 PM
dvourthis's Avatar
dvourthis
I was thinking more like a starter solenoid cut off or something like that, not a fuel or ignition like what I have on my gas truck.
Old Nov 30, 2012 | 12:48 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Find the relay for your FICM (if there is one) and interrupt the power with your kill switch. I would think that would accomplish your goals.
Note: EDIT to delete reference to SPED mod which is 7.3 specific....
Old Nov 30, 2012 | 02:54 PM
Misky6.0's Avatar
Misky6.0
To interrupt the starter, you'd need a high-amp relay under the hood
since the cranking AMPs would over-whelm your 30-amp switch.
But, messing with the thicker cables to the starter is a PITA.
The 6.0 has a fuel pump cut-off behind the pass-side kick panel.
Routing the circuit via your up-fitter should be easy, but somebody
would still be able to ruin your battery/starter trying to get it started.
It only handles a few amps (or less).
This is on my "to-do" list someday.
Old Nov 30, 2012 | 04:58 PM
Blue Jay's Avatar
Blue Jay
You don't need a high amp relay to disable the starter just open the lead that pulls the starter solenoid. Just grab the lead coming from the key switch.
Old Nov 30, 2012 | 11:29 PM
Yahiko's Avatar
Yahiko
Or you can go after all three. FICM relay,Fuel pump relay
and the line to the starter solenoid. But just doing the FICM relay will do what you want.
Yes they can crank it but it won't start.
Sean
Old Dec 1, 2012 | 09:19 AM
dvourthis's Avatar
dvourthis
great advice, thanks guys!
77Lance
Jul 15, 2004 03:10 PM
bajabronco
Electrical Systems/Wiring
Sep 18, 2003 07:53 PM
BBiffle
Jul 22, 2003 11:19 PM
hugobernal22
1997 - 2003 F150
Mar 24, 2003 04:05 PM
77fromheaven
May 2, 2002 01:49 PM
