hosed up ignition
Old Sep 16, 2003 | 12:07 AM
bajabronco's Avatar
bajabronco
Angry hosed up ignition
i have a 89 bronco that starts when it wants with the ignition otherwise i have to jump it off the solenoid. i replaced the ignition switch but that didnt do it. i spoke thegy i baught it from he replace the ignition switch, solenoid, nuetral safety switch and it still didnt cure it. now whats left??????
Old Sep 18, 2003 | 07:53 PM
broken wire's Avatar
broken wire
hosed up ignition
wiring.... I believe it is a red and green wire that goes from your ignition switch through the neutral safety switch to the starter solenoid. Make sure you have power going out the red and green wire at the starter switch while in the cranking mode with a test light, then go to the safety switch, then to the engine bay. Hope this helps.
TreesnFords
Large Truck
15
Mar 31, 2026 04:58 PM
cap4004
Electrical Systems/Wiring
41
Feb 12, 2026 11:38 PM
RangerBee
1983 - 2012 Ranger & B-Series
19
Aug 30, 2014 10:17 AM
bajabronco
1978 - 1996 Big Bronco
17
Sep 18, 2003 10:41 PM
mark78truck
May 11, 2003 08:42 PM
