1972 F100 Steering Column
Old Nov 28, 2012 | 12:40 PM
aggie78's Avatar
aggie78
STEERING HOUSING 1972 FORD F100
I just removed my steering wheel to replace the pointer on my automatic. The signal/horn casing had to be removed by taking off the 2 nuts. Once I did this the whole shifter housing was pushed forward by a spring in the housing. The bolts (where the nuts were taken from) fell out of thier slot. In order to put the housing back together i had to put a rubber band on the bolts to hold them in place while i put on the signal/horn casing; all the while trying to hold the spring loaded shifter housing back. It was a job for a man with 6 hands.
Anybody know an easier way to reassemble the steering housing?
Old Nov 28, 2012 | 02:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I just removed my steering wheel to replace the pointer on my automatic. The signal/horn casing had to be removed by taking off the 2 nuts. Once I did this the whole shifter housing was pushed forward by a spring in the housing. The bolts (where the nuts were taken from) fell out of their slot. In order to put the housing back together i had to put a rubber band on the bolts to hold them in place while i put on the signal/horn casing; all the while trying to hold the spring loaded shifter housing back. It was a job for a man with 6 hands.
AFAIK, this is the only way it can be done.
If you replaced a plastic shift dial pointer (D3TZ-7A110-A), the original shift collar has been replaced. 1965/72 collars had the shift pointer made as part of them.
Ford replaced the 1965/72 collar with the 1973/77 collar that has a slot in it for the plastic pointer to slip into.
Old Nov 28, 2012 | 02:48 PM
Freightrain's Avatar
Freightrain
Welcome to the forums.
Yup, those two bolts are a PITA for sure. Haven't tore one down in quite some time, so I can't feel your pain very well LOL!!
Old Nov 29, 2012 | 09:01 AM
aggie78's Avatar
aggie78
1972 Steering column
Thanks a gozillion! Its comforting to know that I'm not a total nimrod.
Old Nov 29, 2012 | 09:08 AM
aggie78's Avatar
aggie78
Bill,
The switch that is under the dash on the steering column that tells the ingnition switch that the pickup is in park has a lever that pushes the switch into a contact position. The lever on the shaft has come off and i can't seem to make it fit the grooves in the shaft. My question is "can i just tie the wires together so that the switch always indicates the pu is in park" so it will start?
Thanks,
Ray
Old Nov 29, 2012 | 11:37 AM
Freightrain
The neutral safety switch(on the column) also controls the back up lights. There is a flat four pin connector that you can make jumpers to fix that. Two wires for NSS, just make a jumper to plug into each socket. The other two you can hook to a switch on the dash to activate the back up lights.
When I've converted my auto's to stick shift I have done this.
Old Nov 29, 2012 | 01:02 PM
NumberDummy
The Neutral Safety switch (NSS) that is under the dash on the steering column that tells the ignition switch that the pickup is in park has a lever that pushes the switch into a contact position.
The lever on the shaft has come off and I can't seem to make it fit the grooves in the shaft.
D0TZ-7B097-B (replaced C5TZ-7B097-A & D0TZ-7B097-A) .. Spring Steel NSS Selector Lever / Looks similar to this: }--- / 1965/77 F100/350 / Obsolete
Attaches to shift tube thru hole in mast jacket (steering column outer shroud). Knife blade end fits into NSS
What happens to it: Knife blade end snaps off, and/or the little darlin' loses tensile strength and falls off the shift tube.
GREEN SALES CO. in Cincinnati OH has 19 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2,951 (!) = 800-476-9653.
Old Nov 29, 2012 | 05:50 PM
60F100's Avatar
60F100
Although it is possible to bypass the neutral/park safety switch I would recommend against it. It is easy to forget that it is bypassed start it and run into something. I used to bypass them but not any more. Just my opinion.
Old Nov 29, 2012 | 07:16 PM
aggie78's Avatar
aggie78
A friend and I just fixed the problem. Here is what we did. We dropped the steering column from it bracket on the dash; pulled it low enough to work with, put the shifter in neutral, and set the left clip in the slot on the shaft then rotated the shifter over to park and put the right side clip in the other slot. Reinstalled the column and mounted the switch back on the column; adjusting it so that it will start in park.
The rotation while putting in the clip made the job a 100% easier.
Thanks for all the help!!!!!!! Its great to know that many knowledgeable guys are out there willing to share their wisdom!
Thanks again.
xrsfsho
Sep 28, 2015 09:24 PM
Cazman1955
13
Jul 11, 2012 11:40 PM
Wrizer
Jun 21, 2011 07:38 PM
stanyol69
Oct 8, 2008 08:28 AM
tamwill
Dec 11, 2003 10:14 PM
