headers to seal
Old Nov 29, 2012 | 02:02 PM
69highboy69's Avatar
69highboy69
headers to seal
Hello, just wondering if any of you had any tips on sealing headers. from what i can see the flanges aren't bent, I cant take them out without cutting them off or taking my motor mounts off so it is hard to tell. Iv tried bubbling the gaskets but iv gone through about 4 sets of header manifold gaskets, and two collector gaskets and still have a bad leak. Any ideas?
Any help/info would be much apreshated,
jack
Old Nov 29, 2012 | 02:33 PM
Freightrain's Avatar
Freightrain
My '69 has leaked for 20yrs LOL!! I tried the copper gaskets as they were suppose to conform better and not burn out. Yup, still ticks in a few places.
Lay a straight edge across the head and make sure nothing is hurt there. Then the header flange? I usually try to snug all the bolts, then pull the lower ones tight as possible. Then go to the top ones, still trying to work from the middle OUT!
Starting on the bottom ones, then going to the top allows you to pull them tighter. Kinda like wedging the gasket. Since it's hard to get to the lower holes, it's hard to tighten them as much as the top ones. Working from the center towards the outside will help pull the flange flat. If you work towards the middle, it will not pull down as well.
Not that it's perfect, but that is how I've done mine. Though my headers are 24 yrs old, I'm sure that is more the reason why they leak!
Old Nov 29, 2012 | 03:05 PM
MavSprint's Avatar
MavSprint
Re-torque the header bolts after the engine has run a while and check them periodically.
Old Nov 29, 2012 | 07:25 PM
gangstakr's Avatar
gangstakr
I was told this many years ago and have never had a leak. To add to this I torqued mine on initial install, ran the engine for the first day. (Got it good and hot) When cool re-torqued. Did this three times as instructed and have never had a leak. Both engines 292 yblock and 360 FE.
I don't remember what the torque was on either engine, but I did not exceed the torque specs.
Old Nov 29, 2012 | 08:22 PM
first today's Avatar
first today
I had a 70 gmc with headers years back. They leaked like crazy.
A friend had me buy two sets of the cheap header gaskets and soak them overnight in water. He then had me double the gaskets up and install them to the motor. I tightened them up and ran the engine until the gaskets were dry. I re tightened, and never leaked again.
Old Nov 29, 2012 | 08:28 PM
quickshift's Avatar
quickshift
......right down your alley.
Header Leak - 460 Ford Forum
Old Nov 29, 2012 | 08:58 PM
f100today's Avatar
f100today
No gasket at all, permatex copper high temp gasket maker. Works every time
I have done this for years
fordboy97
May 25, 2015 06:20 PM
Rdein
Dec 18, 2014 12:22 PM
tygerrrr
Feb 26, 2013 09:29 AM
71'3604speed
May 10, 2009 11:10 PM
Guttshott
1997 - 2003 F150
Aug 15, 2008 12:59 PM
