Steering column reassembly
Old Dec 11, 2003 | 10:59 AM
tamwill's Avatar
tamwill
It's been awhile since I've been here. Well, I've done it again! I took the steering column apart to see what was wrong with it and now I forget how it goes back together I have a spring, a metal cap (retainer?), and a metal washer lookin deal with two or three ears on it for the bolts. I know the bolts go in from the backside but I can't remember what order it goes back together in. A little help? Thanks In Advance TW
Old Dec 11, 2003 | 03:08 PM
loosenut's Avatar
loosenut
automatic or 3 speed?
Old Dec 11, 2003 | 08:42 PM
BB's Avatar
BB
And what year, it's been a while.
Barry
Old Dec 11, 2003 | 10:14 PM
krazdndenver's Avatar
krazdndenver
Here you go,
The bolts that go in from the back- I place them in the shift housing just starting the nut in the front, then place the housing on, using a small screw driver to push bolt heads into place, easier done then said. The spring goes on almost last, there is an inner spring plate that like a cone, it goes in then the spring then the turn signal switch, ex. Then the steering wheel. Hope this helps, it has been a little bit since I did this but it should be a alright.
Robert
72 F100 Ranger XLT W/ 86 5.0L EFI W/ AOD
www.geocities.com/krazdndenver
