Power steeringpump or hydroboost problem?
Old Nov 26, 2012 | 11:29 AM
Gruntface's Avatar
Gruntface
My truck is making a consistant grunting noise that seems like it is right on the firewall or in the dash. I thought it would be a power steering pump problem. I flushed the old atf from the power steering pump and replaced with synthetic royal purple atf. I never had a squeel like people describe when their power steering pump is having issues. Changing the fluid didn't help my noise go away. When i get out of the truck and go under the hood I can not hear the same sound as while sitting in the driver's seat. There is a certain shakey vibration in the brake peddle and steering associated somehow with my porblem. What do you guys think hydroboost or power steering pump?
Old Nov 26, 2012 | 04:48 PM
duck fan's Avatar
duck fan
Because racetruck
Does the noise change at all when you step on the brake pedal?
Old Nov 26, 2012 | 06:14 PM
Gruntface's Avatar
Gruntface
Ok upon really close observation I realized it got loudest when i let off the accelerator. I got my head down there and it is something to do with the gas pedal. When i let off it is vibrating and the firewall right next to it is vibrating. What is that about? I guess my problem probably has nothing to do with either power steerring or hydroboost.
Old Nov 26, 2012 | 06:47 PM
duck fan's Avatar
duck fan
Because racetruck
Double check the nuts that hold the accelerator assembly to the firewall. Maybe they are loose?
Old Nov 26, 2012 | 06:49 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Is it 4wd? AT? Could be a u joint.
Old Nov 26, 2012 | 06:50 PM
Kdr358's Avatar
Kdr358
Loose torque converter bolts? The slip joint might need to be greased on the front.
Old Nov 26, 2012 | 07:49 PM
Gruntface's Avatar
Gruntface
It is 4 wheel drive automatic transmission.
Old Nov 26, 2012 | 09:32 PM
helifixer's Avatar
helifixer
exhaust down pipe rubbing on transmission?
Old Nov 27, 2012 | 12:31 PM
Gruntface's Avatar
Gruntface
Is it possible for that electric plug on the eccelerator to receive electrical feed back or something like that? Do our accelerators actually open the throttle or do they open by sending a signal based on throttle position?
Old Nov 27, 2012 | 03:19 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Had the same noise for months after i removed my muffler. Come to find out it was the exhaust u-bolt vibrating on the Tranny cross member.
Nathan6.8
Sep 3, 2010 10:56 PM
DieselBeast01
Oct 14, 2009 01:51 PM
drjmoo1
Mar 1, 2009 09:17 PM
FireWarrior
Oct 20, 2008 05:48 PM
SCS
Jan 13, 2005 12:21 PM
