Air intake upgrade??
Old Nov 25, 2012 | 11:48 PM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
Post Air intake upgrade??
Hello, I am new to this forum and am also a new 6.0 owner. I just purchased a 2005 F-250 power stroke 4x4 crew cab Lariat. A friend of mine who is a diesel truck owner (Dodge) suggested that I upgrade the stock air intake/filter system which he said would increase hp as well as mpg. Any truth to this and if so any suggestions. I don't want to re invent the wheel with this truck by doing too many unnecessary or harmful up grades. Thanks
Old Nov 25, 2012 | 11:53 PM
Yahiko's Avatar
Yahiko
That is one of the very harmful up grades. The stock system is very well
engineered and to go with one of the aftermarket systems is asking for a new turbo
the dust and crap that gets around will dust your turbo and make a mess.
The stock system is got enough flow to make it to the 500 HP engines and then
after that point you can change it.
Sean
Old Nov 25, 2012 | 11:59 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
And the stock filter is good for 100,000 miles
Josh
Old Nov 26, 2012 | 12:02 AM
Yahiko's Avatar
Yahiko
Josh,
I forget just how much dirt the stock element will hold.
Some thing like 3Lb I think. That is a LOT of dust.
Sean
Old Nov 26, 2012 | 01:12 AM
Stroker 6.0 fan
Thanks.
Thanks for re enforcing what I was thinking already. Just needed to hear it from another experienced Ford owner.
Old Nov 28, 2012 | 02:54 PM
Chrisdrm10's Avatar
Chrisdrm10
Stock Air
I'm trying to GET a stock air to replace the aftermarket that was installed when I bought the truck used. Anyone know where I can get one cheaper than what Ford will charge me? Thanks!
Old Nov 28, 2012 | 03:02 PM
Bullitt390's Avatar
Bullitt390
eBay or a junkyard.
Josh
Old Nov 28, 2012 | 03:21 PM
AU_Tiger_11's Avatar
AU_Tiger_11
keep the stock and do the zoodad mod
Old Nov 28, 2012 | 03:44 PM
Stroker 6.0 fan
Yes. Check at a wrecking yard. If they don't have it, a lot of yards have a computer system where they can net work with other yards to find it. If not try Craigslist or the internet but be careful. Shipping charges could make it the same or more than if you went to the dealer.
Old Nov 28, 2012 | 06:09 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Question has been answered i know but here's a good write-up with a little more info:
So why do "they" call it an upgrade?
Performance air filter and intake assemblies are a hot aftermarket item. In most cases using one simply means more noise, and more dirt going into your engine. At the dealer we have seen many filter systems changed and for the most part it is obvious that these performance filters offer less filtration evidenced by dirt found in the intake system and worn turbocharger compressor fins. Many of these filters require a coating of oil to aid in filtration. This oil gets sucked in with air flowing through the filter and contaminates Mass Airflow Sensors providing an excellent surface for dirt to stick to. In addition, some intake systems cause erratic airflow through the MAF sensor. Either condition can result in performance concerns or a Check Engine light. For most Power Stroke Engines the stock Donaldson filters are the best choice. In cases where the housings have become distorted or have been broken, the best advice is to replace with the original. We do recognize that the 7.3l PSD F-Series trucks had several filter assembly designs all of which had problems with housings breaking or poor sealing. For that we recommend installing a Motorcraft severe duty upgrade that uses the Donaldson filters.
Diesel Technician Society
Old Nov 28, 2012 | 08:40 PM
Fal-308-Win's Avatar
Fal-308-Win
Originally Posted by Yahiko
Josh,
Sean
It's 8 lbs., where's my water???????
Old Nov 28, 2012 | 10:00 PM
Yahiko's Avatar
Yahiko
Shasta Lake ? You could get one of the Los Angeles Aqueduct as a drinking straw.
Seems that lots of people are getting a drink there
That would be one big drink.
Sean
Old Nov 29, 2012 | 09:31 AM
lakewood's Avatar
lakewood
I was in your position 3 years ago when i bought my 6.0, I bought an aftermarket air filter and it was the biggest waste of money. They don't provide more air flow over stock until your above 3600 rpms I believe. The aftermarket units do not filter dirt nearly as well as the stock filter which I proved to my self after checking the air intake tubing. My MAF sensor hates the AM filter, It makes it read hotter than it should which I've noticed fools with the boost and it actually decreased my MPG's. Stay away from a AM filter and spend the $200 something dollars on a good mod like a coolant filter or a scanguage II.
My AM Air Filter is for sale if you still want one lol
riverrat41
6.7L Power Stroke Diesel
16
Sep 28, 2013 11:54 AM
smokersteve
Oct 25, 2012 02:23 AM
F 250 6 liter
Jun 2, 2010 01:27 PM
southbound35west
Nov 15, 2006 09:49 AM
sting454
Jul 23, 2005 10:04 PM
