1999 Explorer cold starting problem!
Old Nov 19, 2012 | 06:56 PM
gregggy's Avatar
gregggy
I have a 1999 Explorer with a 4.0 engine and when it gets cold it has trouble starting. It will click for a while and then start, but when it is warm I have no problem starting it. Any help would be appreciated.
Old Nov 19, 2012 | 09:29 PM
shorod's Avatar
shorod
The clicking that you are referring to, is that a rapid series of clicks from the starter relay or solenoid? That sounds indicative of a weak battery or a poor/loose connection to one of the battery cables.
How old is the battery?
-Rod
Old Nov 23, 2012 | 03:01 PM
gregggy's Avatar
gregggy
1 year old.
Old Nov 23, 2012 | 05:04 PM
shorod's Avatar
shorod
Since the battery is pretty new, start by making sure the battery cable connections are clean and tight. But, I wouldn't rule out the battery just because it's pretty new. If you have a multimeter it should be pretty easy to test.
-Rod
BigBoyBlue
1978 - 1996 Big Bronco
Feb 12, 2006 06:07 PM
MOMMY64
Nov 13, 2004 07:27 PM
kati
1997 - 2003 F150
Jan 7, 2004 02:34 PM
trevwalker
1997 - 2003 F150
Jan 7, 2004 08:46 AM
goonski
Electrical Systems/Wiring
Oct 10, 2003 09:48 PM
