1978 - 1996 Big Bronco
Battery?
Old Feb 10, 2006 | 01:21 PM
BigBoyBlue's Avatar
BigBoyBlue
Battery?
I have an 86 305 full size. Ive never ever had a problem with this truch once...knock on wood. Anyway The other week I drove to work, ran inside and came back out to try and start my truck and it wouldnt kick. Sounded like the battery was drained. I got a jump from a buddy and I was ready to roll. Thru the past few weeks Ive realized that if I try to start my bronco up cold it starts no problem at all. But when I drive it, turn it off and try to start it again in like 5 minutes the battery seems dead and it wont start and I need a jump. Alternator tested and good...spark plugs and starter almost new. Wiring is clean...no rot rust loose connections. The batterys only a year old its just the fact that it starts fine cold thats throwin me off...any advice?
Old Feb 10, 2006 | 01:28 PM
MichSandSquid's Avatar
MichSandSquid
Have you checked all of your connections to the body and peripherals (sp?)?
Old Feb 10, 2006 | 01:46 PM
masseysbronco's Avatar
masseysbronco
With the engine OFF use a multimeter to check voltage at the battery posts. Should be around 13V or so. Then Have someone put a load on the battery (2 power windows up at the same time should work) if your voltage at the battery drops to like 9V or something, you've got a battery with a bad cell.
If you need a new battery, I reccomend optimias. They cost more at like $125, but the have awesome capacity and they will outlast your truck.
Old Feb 10, 2006 | 02:09 PM
bertha66's Avatar
bertha66
If it starts cold OK, but draging when warm, the timing may have sliped. Also had problems with a starter that would do the same thing.
Old Feb 10, 2006 | 02:53 PM
topfisherman's Avatar
topfisherman
I'd check on that, I have heard of that happening before too.
Old Feb 10, 2006 | 06:01 PM
Streetgang's Avatar
Streetgang
Re-check all the grounds. You could even try using a jumper cable to ground the engine directly, and see how she does....???
Old Feb 10, 2006 | 11:40 PM
busyboy31ca's Avatar
busyboy31ca
I really hope that your engine is not a 305 in a bronco, but im sure we all know what you meant. lol
Old Feb 11, 2006 | 08:20 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome BigBoyBlue to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 12, 2006 | 06:07 PM
Black Ford XLT's Avatar
Black Ford XLT
Battery
Big boy, check your battery and grounds as previously stated, cold weather tends to make our batteries weak if(of any age)Ive had this happen recently thinking it was THE timing ,starter etc.With no load my battery checked 12.5 volts. Best part of it was i have a f-150 and swapped batteries and found the battery was weak . Good luck TR
