A&E Test Done.. need advice please
Old Nov 18, 2012 | 02:54 PM
Talyn's Avatar
Talyn
Originally Posted by blageurt
How old is your ICP ? They are cheap ....I paid 75 bucks for a Ford one on ebay and about 90 for a genuine International one also on ebay ....
Some Ebay ICP's are for 6.slows's and will NOT work on our trucks. =)
Gotta watch out.
Old Nov 18, 2012 | 02:57 PM
blageurt's Avatar
blageurt
No I bought the Correct Ford / International Part # for my truck ... I know the ones you mean though.....
Old Nov 18, 2012 | 03:19 PM
dieselsubmariner's Avatar
dieselsubmariner
i am looking at the following uvch, any objections? :
(i bought from the guys before and had no issue)
Ford 7 3 7 3L Powerstroke Valve Cover Gasket Kit w UVC Harness F250 F350 F450 | eBay
Old Nov 18, 2012 | 03:45 PM
Talyn's Avatar
Talyn
Did some end up being bad on you?
Old Nov 18, 2012 | 04:41 PM
dieselsubmariner
just the external pick tails are bad, but i have been told by several other people, that the harness can ohm out good, but yet still break down under high voltage. and since one side does not want to seal good, i’m just gonna replace both..
and i guess, i will try to find an idm locally at the junk yard.
Old Nov 18, 2012 | 04:43 PM
dieselsubmariner
one more thing:
looking at my data , that oi published at the beginning, it appears , that my ebp is higher than my intake pressure.. im thinking of going ahead and replacing the stock downpipe, and remove the ebp valve... any thoughts on this as well ?
Old Nov 18, 2012 | 05:52 PM
blageurt's Avatar
blageurt
Why Not...
Old Nov 18, 2012 | 06:51 PM
Talyn's Avatar
Talyn
Stock downpipe sucks, and ebpv is useless if you ask me.
Old Nov 18, 2012 | 07:09 PM
dieselsubmariner
thats what i thought.. but for now i had to listen to the boss...
i need to get the truck running right, before i order stuff, that just makes it better ...
i went ahead and ordered the uvch with picktails and new o-rings for my fuel bowl.. to fix one of the leaks :-)
tomorrow i will stop at the local salvage place and hunt for a used idm.
Old Nov 19, 2012 | 11:23 PM
oldbird1965's Avatar
oldbird1965
My clips broke several years ago, no big deal.
Old Nov 28, 2012 | 08:08 PM
dieselsubmariner
what now?
OK.. i replaced now the Under Valve cover harness and also replaced the picktails on the engine harness.. I had the engine harness out , inspected it and replaces the split loom covering on the harness.
Did Buzz test a couple times. IDM Failure again and #3 does only buzz very quiet.
When starting the Truck, same results as before..It starts easy but does not run right , skips, runs rough, smokes white under acceleration over 2000rpm. and does not have power... all Values, ie oil and so on are good.
Once the the Truck was warm, it straightened out and runs fine.. Tried CCT test, but it failed and gave me a Transmission range sensor not detected..
once turned off, did buzz test.. idm failure again, but all injectors fire...
NOW What
don’t know if it helps, but even with the truck warm (no visible smoke) , it burnes your eyes if you stand next to the exhaust
Old Nov 28, 2012 | 09:02 PM
oldbird1965
If your getting that burning its inadequate burning of the fuel caused by low HPOP pressures. Change the IPR.
Old Nov 29, 2012 | 05:24 AM
  #28
dieselsubmariner
you do believe it is the IPR ?
I had it out and cleaned it and all looked good though.. Also i have an hpop pressure at 600 on idle and between 2400 to 2500 at wot.
Old Nov 29, 2012 | 06:49 AM
  #29
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Pull solenoid off the #3 injector (second one back from the front, passenger side) and try to slide a feeler gauge under the Armature plate (small 1" square plate you'll see with solenoid off.)
If you can't get a .0015" feeler under there, then the injector is probably causing the issue.
If the injectors are still original to the truck, they will all be in about the same condition and can be causing you grief.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Nov 29, 2012 | 07:24 AM
  #30
dieselsubmariner
now .. thats a good info i can use, just wish i had known this last weekend). is there anything elese i can test on the injector, while i have the valve cover off AGAIN :-)
thanks a lot
chasteen1156
35
Nov 5, 2025 09:37 PM
akorcovelos
Jul 13, 2024 03:01 AM
pstrokemike97
Mar 15, 2019 09:52 AM
caseydudem
Jan 1, 2008 11:40 AM
bobert64
Mar 27, 2007 11:14 PM
